GTP heads and cam question.
What is the biggest cam you can run without having to cut your pistons if you use a 5.7 GTP head that has been milled .30 ?????
I need something that is big and nasty, and will work with nitrous. Main goal is max horsepower NA and using my TNT 150 wet for "ace in the hole". I will be using racing gas, with a nearly wide open exhaust (bullets and dumps with Hooker Super Comps) TH400 with 4000+ stall.
Please help!
Please help!
