Need new heads
Old 09-25-2011, 03:09 PM
lunatikgixxer's Avatar
Default Need new heads
Ok im on a pretty tight budget here but ive been thinking about getting some new heads lately. I have a tsp 233/239 cam and stock intake. What are pretty much all my options? Ive heard of truck heads and getting them Ported.. Could i go to the junkyard and take some heads off a truck? If so which trucks should i look for.. Id like a nice list and best bang for buck. Im not really going for all out max peak hp, mainly bang for buck. thanks!
Old 09-25-2011, 03:55 PM
LSOHOLIC's Avatar
Not trying to be a dick but.....you should probably start with...
Make
Model
Engine
Current heads
Transmission
Intended use
Future mod plans
HP goals
ect......anything that will help us point you in the correct direction.
When you mentioned 317's, that makes me think you may have FI plans down the road. If not I would not increase CC volume with your current cam.
Thanks...there are lots of guys willing to help...just give us a little more details.
Old 09-25-2011, 04:20 PM
PREDATOR-Z's Avatar
Just take the heads of your 2000 motor and send them to AI for P&P. Best bang for $$.
Old 09-25-2011, 05:04 PM
LSOHOLIC's Avatar
I agree with Predator-Z some what.....those are two of the three leading CNC shops (OEM castings). The one he forgot is TEA. Just do a search of the three mentioned...can go wrong with either.
I assume we are talking 241's ??
Thanks....
Old 09-25-2011, 05:42 PM
PREDATOR-Z's Avatar
On a 2000? not 241s, those were 01/02
Y2K were 853s
Old 09-25-2011, 05:58 PM
LSOHOLIC's Avatar
Gottcha
I'm out of touch with F-body part #'s, sold mine 4 years ago and bought a ZO6. Plus mine was a V-6 hardtop model that I transplanted a LS into.
Thanks for the education...
Old 09-25-2011, 06:04 PM
oange ss's Avatar
Y2K were 853s
I've seen late model year 2000's with 241 heads
Old 09-25-2011, 09:46 PM
yeah its a y2k ws6 with stock heads. One reason im wanting to get new heads is because i stripped one of the spark plug threads going into the head one time when i changed the plug so it sits in there kinda crooked and not all the way in... If im going to take the heads off i might as well put different ones on. In the future yes i would like to go FI but as of right now i just need a replacement, and id want to upgrade a little in the process.
Old 09-25-2011, 09:59 PM
KCS
Moderator
KCS's Avatar
Yup, I had 241's on my 2000 Trans Am.
Old 09-25-2011, 11:37 PM
mike c.'s Avatar
Do it right one time. forget the low cost bang for the buck get a free toaster with heads. get some new AFR heads and you will be happy you did.
Old 09-26-2011, 12:03 AM
RedRallyeZ's Avatar
There was a thread somewhere just a few days ago with people finding 243/799 heads for around $450 on ebay. You could then turn around and send those off to TEA and have a killer head
Old 09-26-2011, 12:36 AM
lemons12's Avatar
A ported 243 head from ai would outflow a set of out of the box 205s... Not to mention you will have a little over a grand in the ais and 1800$ in a used set of 205s.
Old 09-26-2011, 06:31 AM
sounds like 243s is the way to go. Those are the ls6 heads correct?
Old 09-26-2011, 07:35 AM
PREDATOR-Z's Avatar
Correct but they are few compared to 853s
Old 09-26-2011, 08:48 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Give us a call & we can discuss options for your combination. We setup custom milling on our PRC cylinder heads to specifically match your camshaft. We have tons of experience with the 233/239 and cylinder head selections! We just finished a car that got PRC LS6 heads & fast intake and gained right at 65rwhp.
Not to mention for the $$ the PRC stage 1 ls6 heads are really a great buy & currently on special!
http://www.texas-speed.com/p-1391-pr...ted-heads.aspx
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 09-26-2011, 09:15 AM
garygnu's Avatar
you can use 799 heads also.check out all the head porting vendors and see what you can afford.
Old 09-26-2011, 02:49 PM
lemons12's Avatar
Correct.
Old 10-01-2011, 08:41 PM
00silverGTP's Avatar
yeah I just picked up 243s from ebay for $400 shipped...
Old 10-02-2011, 11:30 PM
gonzo 6.2's Avatar
These?
Possible these are truck heads ???
http://cgi.ebay.com/ebaymotors/799-2...item43a9c4adb1
Old 10-03-2011, 09:13 PM
no it wasn't those.
