Rocker "tap?"
Old 09-27-2011, 07:19 PM
CHADsterss's Avatar
Default Rocker "tap?"
Hey guys I know the LS1 is knows for the infamous "tick," but this has been bothering me for the longest time. I hear a ticking sound for the passenger side of my engine it tends to speed up as my RPMs go up. I have done plenty of research on this forum but just cant get a 100% conformation on this cause I've seen people saying it could be the oil pump or even a spun bearing... I'm just not sure, thanks in advance!
Old 09-27-2011, 08:44 PM
3rdCoastPowerSports's Avatar
if you can post up a video and let us help you diagnose it
Old 09-27-2011, 09:12 PM
CHADsterss's Avatar
Sure, I'll have it up tomorrow.
Old 09-28-2011, 11:32 AM
CHADsterss's Avatar
Here are two videos of it, one from a cold start up and the other is after the engine has warmed up.
http://www.youtube.com/watch?v=sAo3GMdg9-Y
http://www.youtube.com/watch?v=nD3T62b-qZI
Any Ideas?
Old 09-28-2011, 11:51 AM
LilJayV10's Avatar
Have you checked for exhaust leaks? I had a header leaking and I was convinced it was the valve train till I fixed it.
Old 09-28-2011, 12:04 PM
CHADsterss's Avatar
Hmmm no I haven't. I literally just took this video, I'll let her cool down then go check.
Old 09-28-2011, 12:10 PM
LilJayV10's Avatar
My exhaust leak was on top of the header collector bouncing off the floor pan. It echoed up the floor into the engine bay. It was really bad around 2500 rpm when I was driving it. I couldn't believe it was an exhaust leak.
Your noise doesn't seem to have a high enough pitch to be a rocker. I could be wrong though. Let us know what you find out.
If your leak is bad enough you will probably be able to see soot where it's leaking or start it when it's up and jack stands and put your hand around the connections before it gets too hot.
Old 09-28-2011, 12:36 PM
01formula6's Avatar
I had a similar noise before, ended up being that the #7 spark plug was a little loose.
Old 09-28-2011, 02:37 PM
CHADsterss's Avatar
Check for exhaust leaks and I couldn't find any, I also check the spark plugs and they were all good too. I found out Its hard getting to the passenger side of the engine there is zero room lol
Old 09-28-2011, 02:55 PM
NC98Z's Avatar
I had a crack in the pipe that comes off the headers for the EGR Valve. Never could find it until it finished cracking and fell off. Then I just took a wire fed welder and welded what was left closed.
Old 09-28-2011, 04:18 PM
CHADsterss's Avatar
Hmm... I'll have to check that.
Old 09-28-2011, 09:12 PM
CHADsterss's Avatar
So let's say it is the rocker tapping on the valve cover, is it anything I have to worry about?
Old 09-28-2011, 09:32 PM
RARON455's Avatar
Yes it would be something to worry about,,but I Dont think the rocker could actually hit the cover, But if it is loose, that could be the source of the noise and could cause considerable damage,, Pretty easy to just pull the cover and have a look, If you want to be certain, Pull the rockers off, and take the pushrods off, then roll them on something flat, if they roll smooth you know they are straight and not bent. Then re-install and torque the rockers to spec,, 22 ft. lbs. The only thing this will cost you is about 12 bucks for a set of valve cover gaskets, and some time,, But It will give you piece of mind...
Old 09-28-2011, 10:24 PM
WS6ICK2k's Avatar
Def not piston slap I have same issue in mine by disappears at any rpm over idle such as 1200 RPM.
Old 09-28-2011, 11:53 PM
LilJayV10's Avatar
I think if the rocker was loose enough to hit the valve cover the noise would be way worse than that and it would probably jump off the pushrod.
As Rarron said the next thing to do is pull the valve cover off. First look for any obvious problems, needle bearings laying in the head, broken spring(not that I think that's it just an example)
Turn the engine over and wiggle each rocker when it has no lift on it and see if any look/feel different. If you don't find anything start pulling the rockers off. Look at the valve tip and the end of the rocker and inspect for excessive wear.
Depending on how bent a pushrod is you might find a rocker arm that's loose.
Can you tell which cylinder the noise is coming from? I would get a stethoscope and put it on top of the valve cover and listen while the engine is running. You will hear the echo of the tick but when you get close to it it will be amplified. Doing little stuff like that and checking things will help narrow your search down instead of pulling the valve cover off and just tearing in to it. Let us know what you find.
Old 09-29-2011, 12:14 PM
98blkz28's Avatar
So i think mine is doing it as well, the other day I had low oil light and pressure..checked oil had 2.5qts wtf!!! Changed oil and still tick...there are needle bearings in my oil which some forums are saying its the rockers, i have them, just havent changed them....but also as some pages say... it could be oil pump (my oil gauge is ticking around 40)...then maybe lifters, or exhaust or i dont know!!! HELP LS1TECH YOU ALWAYS DO!!!!
Old 09-29-2011, 12:24 PM
98blkz28's Avatar
http://www.youtube.com/watch?v=F78hz0ViA58
Old 09-29-2011, 12:47 PM
CHADsterss's Avatar
Originally Posted by 98blkz28
Wow seems like its the same exact thing as mine, I haven't torn into it quite yet but when I do and if I find out what it is I'll give yall a update
Old 09-29-2011, 01:14 PM
gMAG's Avatar
I've got a similar sound near #7. It sounds like the rocker/pushrod clearance is too much.
Old 09-29-2011, 01:27 PM
98blkz28's Avatar
neither have I, I have the rocker arms. Bc the needle bearings are coming out, so idk if that could be the issue.
BUT YES PLEASE UPDATE ME!! I'm Gonna open it up soon too!
Quick Reply: Rocker "tap?"
