Pushrod Strength Questions.
Old 09-28-2011, 07:36 PM
99 Blue Bird's Avatar
Default Pushrod Strength Questions.
Are all aftermarket chromoly 5/16 pushrods created equal? like are the comp cams, trickflow, TSP pushrods all the same? they are all made from heat treated one peice chromoly so what makes other brands better than their competition?
Old 09-28-2011, 07:40 PM
JS01's Avatar
For the most part any of the 5/16 pushrods you listed are equal. Most of them are made by the same manufacturer anyways (Trend mainly, some Manton and Smith Bro's). Wall thickness and overall diameter are the two main specs on a pushrod that determine how "good" it is. 90% of the pushrods the LSx parts slingers sell are .080" wall 5/16" dia. which is the pushrod equivalent of spaghetti. The minimum I'd prefer to use even on a mild cam deal with relatively low spring pressures are 11/32" .135" wall, 3/8" preferred.
Old 09-28-2011, 07:48 PM
lol so i take it "spaghetti" pushrods = thin pushrods? whats the best 5/16 pushrod to buy? cuz in my case a 3/8 pushrod seems overkill. how thick are stock pushrods anyways?
Old 09-28-2011, 08:20 PM
ZeeOSix's Avatar
Chew on this for awhile ... especially page 2.
https://ls1tech.com/forums/generatio...ness-spec.html
Old 09-30-2011, 04:50 AM
vettenuts's Avatar
I looked into this when I upgraded my pushrods to 3/8" double taper. In the end, the hp curve above 6,200 climbed with the stiffer pushrods. From a hp standpoint, I gained about 6 but that was not the reason for the pushrod swap. The fact that there was a change at all indicates the pushrods were flexing and causing instability in the valve train at these RPM's so that the longevity of the setup should have increased with the stiffer pushrods as well.
Pushrod Stiffness Comparison
Quick Reply: Pushrod Strength Questions.
