Thinking about a 228 cam... opinions?
Old 03-08-2004, 10:26 AM
Tranzor's Avatar
Default Thinking about a 228 cam... opinions?
Hey everyone,
I'm slowly starting to get to the point where I'm ready to put a cam in my car... been doing a lot of research here, and I'm starting to really like what a 228/228 cam has to offer. Looking at .571/.571 on the lift to keep it a little less harsh on the 918 valve springs...
Anyhow, how driveable would this cam be with an M6 on a 112 lsa? Also, what RPMs would a cam like this peak at? I'd like to not have to spin it past 6500 or 6600 RPMs. This car only gets driven about 3 times a week, but is commuted to work (through traffic of course) at least once a week... otherwise it is mostly a weekend vehicle.
I'll be getting a custom Predator tune once I get the cam in. Would like to hear from some people who have cams similar to this... and what kind of idle issues they've had.
I've also considered getting a 224 cam, or a 226 cam. Any opinions will be appreciated, as always.
Old 03-08-2004, 04:42 PM
dheck's Avatar
That cam wouldn't idle too bad with a good tune. I have a 231/231 in my auto and it idles really bad at start up due to tuning issues. But after it warms up it idles just fine. That cam will probably make good power up untill 6200 RPM.
Old 03-08-2004, 04:59 PM
samz28's Avatar
dunno my 224/226 .570/.571 112 lsa peaks little higher than 6200rpm
the 112lsa on the a4 is a little bitchy on cold starts
Old 03-08-2004, 05:21 PM
98SS Blackattack's Avatar
The FMS F4 has been turning great times with stock heads.Great under the curve.Its A 114lsa also..
Old 03-08-2004, 05:39 PM
Smallwood's Avatar
I have the Futral F10 228/581/112 in my daily driver. It drives just fine in bumper to bumper traffic and runs like stink.
Old 03-08-2004, 06:44 PM
Tranzor's Avatar
Now that's what I like to hear!
Old 03-09-2004, 02:18 AM
DG Gordon's Avatar
My buddy has that cam or one very much like it in his TA. It is a 228/228 571/571 112 ls. It is an auto and it idles worse than my much bigger cam. It makes for a great race cam as it made 382 rwhp and 435 rwtq in an auto with 4.10s and a 4400 stall. It has 5.3 stage 2 heads and custom tuning. If this is the same cam you have it will need custom tuning for sure even though it is a m-6.
Old 03-09-2004, 06:48 AM
Smallwood's Avatar
Yeah, mine didn't run worth a flip with the stock tune. But anytime you install a cam you should have the car tuned.
Old 03-09-2004, 04:41 PM
BDD
BDD's Avatar
I just got my 228/228 .588"/.588" 112lsa on Friday. Can't wait to put it in. I will post my results.
Old 03-09-2004, 04:53 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We stock the 228 camshafts with 588 lift. The 588 lift camshaft definately idles better than the lower lift xe lobes.
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 03-10-2004, 12:14 AM
Tranzor's Avatar
Jason
It'll idle better than the .571 xe lobe, huh? Interesting... so how are the .588 lift camshafts on the 918 springs? And about where do these cams like the shift points to be (RPM wise)?
The more I hear, the more I like this grind...
Old 03-10-2004, 01:03 AM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
Tranzor, don't look at the camshaft specs @ .050" only. The difference between a 228xe lobes and a 228xer lobes are much more different than you would think other than the big difference in lift. I would be thinking with the slower ramp rates of the 228xe lobe that its actually ends up being a bigger cam than the 228xer lobe'd cam if you go by advertised duration, or duration measured at .006". I don't have the cam cards here to check though. Anyways its not enough of a difference to really matter as far as power numbers. Although I've never had done any back to back testing on 228 vs 228R.
918 springs have always done really well for me and the many customers I've installed them for. I've never had any problems with them or seen any firsthand problems. The only springs I've seen break were the REV duals on a G5X2 car. If you want better piece of mind we sell the Patriot dual springs or Crane Dual springs that will both fit without machining, you would have to change to the earlier style valve seals, but everything needed should be in the dual spring kits.
Old 03-10-2004, 01:25 AM
03EBZ06's Avatar
Thumbs up
Originally Posted by Tranzor_Z28
Hey everyone,
Anyhow, how driveable would this cam be with an M6 on a 112 lsa? Also, what RPMs would a cam like this peak at? I'd like to not have to spin it past 6500 or 6600 RPMs...
Call Comp Cams and order an XE-R lobe. Believe they charge 379.00.
I run a 224/228 XE-R, 113, 581,588 and the cam just kicks butt.
Dynoed 454/417@ 6600rpm. Spinning the tires,idle launch, and a poor 60ft, still the car ran a 11.8@122. Next time out I expect to see a low 11@124. I would say thats a good cam considering I have stock muffers and tail pipes.
At idle, its almost as smooth as stock and at wot, it really helps the car wind up. I think the 228/228 would make a great cam, just make sure and get the
XE-R lobe, its better.
Old 03-10-2004, 11:03 AM
Tranzor's Avatar
Cool, thanks for the info Joseph! And you too, Jason! Very helpful stuff for sure...
Old 03-10-2004, 07:10 PM
Trevor @ Texas Speed & Perf.'s Avatar
The cam we label as a 228R (228/228, .588"/.588", 112 LSA) was the second camshaft that we tried in my '02 SS A4 with stock heads. We tried a few different cams varying nothing else but LSA and advance ground in to come to the best overall setup for driveability, idle quality, and p-to-v clearance. I ran a best of 11.41 @ 116.85 MPH on a 1.53 60' with STOCK cylinder heads and a 3,526# raceweight on a BFG drag radial with this cam! It's a very proven cam that makes fantastic power. Even after adding ported cylinder heads, the car would still get 23.5 MPG on the highway at 75 MPH with 3.73's and the a/c blasting! I drove the car daily and took it on quite a few road trips, the longest being 600 miles in a weekend. So long as you have some good custom tuning, the cam will work great.
Feel free to give us a call if you have more questions. We're always here to help.
Trevor
__________________
Old 03-10-2004, 07:27 PM
Nasty N8's Avatar
If you are interested I will be pulling the cam out of a shop car. The cam was installed with the new motor 2 months ago and with the Chicago weather it has gotten about 800 miles on it. Runs great just want to try something larger now.
Comp Cam 228/230 .571 .573 112
Just an option
Thanks Nate
