TFS/TEA 215 Flow Numbers **with results**
Old 09-29-2011, 06:37 PM
10 Second Fun Car
jlrz28's Avatar
Default TFS/TEA 215 Flow Numbers **with results**
.100 68.4 61.9
.200 139.7 119.7
.300 218 186.7
.400 270.3 230.3
.500 306 255.4
.550 317.8 264.5
.600 324.2 269.1
Results
https://ls1tech.com/forums/dynamomet...102-nw102.html
Old 09-29-2011, 06:56 PM
Darkman's Avatar
If you are having TEA assemble the heads you ought to consider having powdered metal valve guides installed if you are thinking about stock rockers. Also coordinate the cam selection with your decision regarding compression ratio so they can mill the heads accordingly.
Old 09-29-2011, 07:05 PM
10 Second Fun Car
jlrz28's Avatar
It's already done
60cc
turned down ls3 valves
stock rockers with trunion
EPS Cam
Old 09-30-2011, 02:10 AM
pimpdulla's Avatar
Originally Posted by jlrz28
It's already done
60cc
EPS Cam
How much additional $ for the turned down Ls3 values and milling the heads?
Old 09-30-2011, 07:59 AM
10 Second Fun Car
jlrz28's Avatar
$180 for the Valves
$60 for the mill
Old 09-30-2011, 08:46 AM
MM98's Avatar
Those heads are gonna be so much better with those LS3 valves.. Things gonna rev quick & be stable with that light valvetrain, nice job man!
Old 09-30-2011, 12:53 PM
98blueSScamaro's Avatar
How much did she put down just got off the rollers with a friends ride...
TEA stg 2.0 243's 60cc
ls3 valves
Stock upgraded rockers
EPS Cam
fast 102
car is nasty
243's for the win
And look how flat the curve is.... so sexy
Attached Thumbnails TFS/TEA 215 Flow Numbers **with results**-019.jpg
Old 09-30-2011, 02:28 PM
10 Second Fun Car
jlrz28's Avatar
What cam is he running? I am hoping to do 430+ with a flat tq curve. My car has never been a great peak number car. So I figure hope for small numbers and if I get bigger it's a plus.
Old 09-30-2011, 02:47 PM
its a baby cam 234/242 604/605 112+3
Old 09-30-2011, 03:08 PM
MM98's Avatar
ls3 valves
EPS Cam
fast 102
car is nasty
243's for the win
Damn that's impressive.. Question, what size are the LS3 valves ground to on those heads, 2.02 or 2.04?
Old 09-30-2011, 03:37 PM
tea can only cut them to 2.04 i wish that they were able togo to 2.02 cuz i would have a set ....
Old 09-30-2011, 03:55 PM
MM98's Avatar
Right on.. I'm thinking about adding a set to my PRC 2.5 243's.. I have an early set that came with 2.04 intake valves vs the 2.02 they use now.. I wonder why they went to a 2.02 from a 2.04, possible shrouding issues on a 3.90 bore? Though that doesn't seem evident on your friend's 243's.
Old 09-30-2011, 04:06 PM
most run the 2.02 with the 243's because the chambers seem to like the 2.02 but tea gets the 2.04 to work
Old 09-30-2011, 04:31 PM
10 Second Fun Car
jlrz28's Avatar
A4 or M6?
Old 09-30-2011, 04:58 PM
_GTO_'s Avatar
It's already done
60cc
EPS Cam
Nice combo .
ls3 valves
EPS Cam
fast 102
car is nasty
243's for the win
Damn , that's so sexy <3.
346 ci ? stock internals ?
Old 09-30-2011, 05:05 PM
_GTO_'s Avatar
I was wondering the same thing , alot of people say that the 2.04 valve hurts the flow beside the clearance problem , let us hear from the experts .
Old 09-30-2011, 07:46 PM
Originally Posted by _GTO_
Nice combo .
Yes SBE 346 LS1 stock pistons fly cut .80
Chamber work has a lot to do with it
A4 or M6?
M6 and on other pull's with less timing it was making 433TQ
Old 10-01-2011, 09:05 PM
supergt99's Avatar
i just bought myself a set of TFS 215's. cant wait. im changing from TSP 2.5 5.3 heads.
Old 10-02-2011, 08:16 AM
_GTO_'s Avatar
Thank u 98blueSScamaro for the help
Old 10-03-2011, 05:31 PM
10 Second Fun Car
jlrz28's Avatar
Got the cam today....
EPS 226/234 .598 .601 113+2
Quick Reply: TFS/TEA 215 Flow Numbers **with results**
