Timing Chain Damper, who's runnen them?
Old 10-01-2011, 10:12 PM
3rdCoastPowerSports's Avatar
Default Timing Chain Damper, who's runnen them?
just like the title says... Who's Runnen them? Who has swapped cam's and doesn't have a damper?
i've read several threads of broken timing chains and most if not all of those broken chains didnt have dampers.
anyone regularly race there motor without a damper?
Old 10-02-2011, 01:42 AM
ls1 1990 VN's Avatar
I Road raced my weekend car once a month '7 meets a year' for around 10 meetings & broke my dual Rollmaster due to no dampener.
Drag racing does not cause the same whiplashing of the chain.
Old 10-02-2011, 03:25 AM
01ssreda4's Avatar
What kind/year of engine are you running?
Old 10-02-2011, 09:20 AM
kkslds's Avatar
I purchased a dampener and c5r chain both from Katech for my current build. I don't road race, but its additional piece of mind.
Old 10-02-2011, 09:29 AM
bluehawk2's Avatar
I put one on my new ls2 build, but as far as I know there isnt bolt holes to install one on the earlier ls1 blocks..?
Old 10-02-2011, 01:06 PM
Rich92RS's Avatar
I also bought one for piece of mind for my build. My block is a 98 LS1, and it had the holes pre-drilled already. Some 98 blocks came pre-drilled.
Old 10-02-2011, 01:51 PM
2002 Ls6 block. It has the holes drilled for the damper. The new timing set I put on has some slack in it and also seems that the cam gear sits farther into the block than the crank gear (maybe. 006") so the chain looks slightly uneaven (vertically). This is making me worried and that's why I was asking about dampers
Old 10-02-2011, 02:00 PM
Zmg00camaross's Avatar
Who sells chain dampners?
Old 10-02-2011, 02:17 PM
Katech i think still has a few LS1/LS6 left and the LS2 you can buy anywhere and not to mention are about 80% less expensive than the LS1/LS6 damper
Old 10-02-2011, 03:37 PM
Rikoshay's Avatar
I got my dampner from Rock Auto Parts for $10. Application is 2005 Chevy Trailblazer w/ a 5.3L engine.
Put it on a 2001 iron block 5.3L. Didn't drill the holes all the way thru, shortened the bolts. Found the M8x1.25 tap at Home Depot. It was fairly easy to drill/tap and install since my engine is on a stand.
Old 10-02-2011, 03:41 PM
Rikoshay's Avatar
Also got an LS2 timing chain for my engine. Rock Auto Parts had that for $32 and it is an LS2 chain. The side links on the chain are twice as thick as the original chain.
Old 10-02-2011, 03:59 PM
chrisfrost's Avatar
Just FYI ,,,,,,from what I understand the main reason t-chains break at least on the LSx gen 3's n 4's is running at a fairly constant high rpm like in road racing ,,,,,,,somewhere between 3500 n 4500 I believe is the "not so sweet spot" ,,,,it has to do with high frequency vibrations causing alot of harmonics ,,,blah blah ,,,,,,,,,,,,,,Ya I got my LS2 timing set at RockAuto also but was $28 at that time ,,,,which was only about 6 or 7 mo ago . Yes I'm gonna probably pick up one of those dampers myself ,,,,,,,,can't be too cautious with these engines .
Old 10-02-2011, 04:19 PM
01ssreda4's Avatar
That looks like the newer version which will not work on OP's engine.
Old 10-02-2011, 05:08 PM
does anyone know the center bolt to bolt spacing on a LS1/LS6 damper and the center bolt to bolt spacing on the LS2 damper?
also i was thinking about the lack of timing chain vertical alignment and i think im all good and its normal,,, you have your crankshaft run out, your crankshaft end play, camshaft run out, camshaft end play and im sure all of that is playing a factor in my lack of chain vertical alignment,,,, im sure when its up and running those clearances will equal out.
Old 10-02-2011, 10:37 PM
01ssreda4's Avatar
Old setup was like 2.1" and tan and the new one is 1.7" and black.
Quick Reply: Timing Chain Damper, who's runnen them?
