408ci CR/and hp/tq # est.?
Old 10-03-2011, 01:03 AM
ocls1's Avatar
Default 408ci CR/and hp/tq # est.?
I am building a 408 with the following:
Callies compstar crank
Callies LSC I beam rods
Diamond flat top Piston -2cc valve relief
317 milled to 68cc w/3 angle valve job and slight port work
g5x2 cam
stock gm lq9 gasket
ls6 intake
I was wondering what HP/TQ #s do you guys think ill make through a m6 also what compression ration would I be at?
any input is appreciated!
Old 10-03-2011, 05:09 PM
ocls1's Avatar
anyone?
Old 10-03-2011, 08:48 PM
ABQ99TA's Avatar
http://www.csgnetwork.com/compcalc.html
Old 10-04-2011, 11:53 AM
dkota1968's Avatar
Sounds like a good budget build, would be very interested in results, thinking similar build in a yr or 2.
Old 10-04-2011, 01:50 PM
ocls1's Avatar
Its not to bad!
Originally Posted by ABQ99TA
for some reason i cant get it to work correctly... im getting 18.3 and then 8.9 lol
Old 10-04-2011, 11:20 PM
ABQ99TA's Avatar
I found 11:3-11:9 depending on a few things what numbers are you using?
