Z06 cam?
Old 10-03-2011, 08:31 PM
Big Matt's Avatar
Default Z06 cam?
I went and looked at 2 cams today that the guy said were ls6 / z06 cams. I couldn't find the part numbers list as a ls6 cam so some help would be great. I guess what I am asking is what are these 2 cams out of?
Part number 1) 17215042238
Part Number 2 09654008345
Thanks
Old 10-03-2011, 08:41 PM
Darkman's Avatar
The part number for a GM LS6 cam is 12565308.
Old 10-03-2011, 10:53 PM
Big Matt's Avatar
[IMG]http://img.photobucket.com/albums/v170/StangOnSpray/cam1.jpg[/I
These are the 2 cams. He is adamant that on of them is a Z06 cam. If they arent please let me know what the came from.
Thanks
Old 10-03-2011, 11:28 PM
Whiteaw57's Avatar
wierd barcode type deal on the bottom. Only place Ive ever seen that before is on a Nascar K&N spec engine. They use it to tech the legal parts for the engine. I dont know what you have there though
Old 10-04-2011, 05:03 AM
RDKingWS6's Avatar
Those are stock ls1 cams. 0965 came in 99-00 ls1 and the 1721 came in 01-04ls1. For a z06 cam ur gonna look for these top 4 numbers.
01 z06-0950
02-04 z06- 5308
Old 10-04-2011, 06:01 AM
Darkman's Avatar
This has come up before
https://ls1tech.com/forums/generatio...04-2123-a.html
https://ls1tech.com/forums/generatio...-camshaft.html
Old 10-04-2011, 06:22 AM
Big Matt's Avatar
Thanks guy you saved me from making a mistake.
Old 10-04-2011, 06:29 AM
Captain Double Post
BOBS99SS's Avatar
yeah dont buy those, can i ask why you want to go with a ls6 cam? tell that guy he should check out what he has before he rips someone off,always check part numbers if your not sure
Old 10-04-2011, 07:14 AM
PREDATOR-Z's Avatar
http://chevythunder.com/LS1%20components.htm
Old 10-04-2011, 08:19 PM
Big Matt's Avatar
It was recommended by a friend that knows a ton about LS1, I a building a pretty mild 6.0 with a 76 mm turbo on it.
Old 10-04-2011, 10:27 PM
garygnu's Avatar
get a custom cam to get the most out of a turbo build.talk to Patrick-G for a good cam.
Quick Reply: Z06 cam?
