Assuming no codes (SES light) most probable causes are plugs or plug wires or bad motor mounts. This also assumes vibration levels beyond the normal for whatever cam you are running.
Vibration occurs at idle when in drive. Happens intermittently. Thanks
does it only occur in drive or does it do it in neutral and park? ex. if its doing the vibration thing and you throw it in neutral does it still vibrate?
Mine is stock and doesn't vibrate but shakes in an idle almost as though I have a cam. hahaha. **** it. if it drives and doesn't tak I think your okay for now.
