aluminum 5.3 vs iron 6.0. Want to trap 124mph..
Old 10-06-2011, 08:08 PM
dean85gt's Avatar
Default aluminum 5.3 vs iron 6.0. Want to trap 124mph..
Here a bit of info.
Car is a foxbody mustang. Weighs 2850 with iron 5.0 and 5 speed. Full drag suspension.
Im looking at swapping in either an Aluminum 5.3 (L33) or an iron 6.0 with a T56.
The engine will be carbed with a vic jr, longtubes and 3 inch exhaust.
The only mod I want to do to the engine is put in a cam (even leave the heads bolted on). I dont have to worry about emissions so the cam can be large.
Is it going to be possible? I know its a lofty goal but the car is quite light. Is the weight savings from the aluminum block worth the 0.7L less of displacement.
Enlighten me.
Thanks
Old 10-06-2011, 08:43 PM
GIVE EM' THE BIRD's Avatar
If your not gonna mod it past the cam and have the need for the iron block then I'd go aluminum... Power will be relatively close either way I think.
Old 10-06-2011, 10:51 PM
95ONE's Avatar
No way. Go cast iron. You know you won't stop at cam. The Iron affords you more growing room. I love the L33's though. Have one myself bored out to 5.7. If you want to trap 124, You're going to need around 450 wheel horsepower.
The term "light" is relative. I've always felt <2500 is the beginning of light.
Old 10-06-2011, 11:04 PM
PREDATOR-Z's Avatar
The 6.0 with the 4.0 bore is the way to go. Done right all you need is about 420>430rwhp which is much more easily available with a 6L
Old 10-07-2011, 06:05 AM
dean85gt's Avatar
Would the ly6 be a much better option?
Old 10-07-2011, 07:17 AM
redtan's Avatar
Why not an aluminum 6.0, they're not that much more expensive.
Old 10-07-2011, 09:05 AM
dean85gt's Avatar
LY6 can be had for like 1500 around here (canada). For an LS2 I would have to fork out over 4k
Old 10-07-2011, 09:06 AM
dean85gt's Avatar
I agree but its not a stripped out race car. Its a street car with a full interior
Old 10-07-2011, 09:12 AM
redtan's Avatar
That's pretty damn cheap for a longblock. What's the compression on that thing, cuz don't truck motors come with bigger head chambers?
There's a 60k LS2 going for 2500 shortblock and 3000 long block on ls1gto.com, that's not bad considering it's lighter and has more compression than a truck motor.
Old 10-07-2011, 11:08 AM
99 Blue Bird's Avatar
might make you more comfortable going with a 5.3 knowing what its capable of
https://ls1tech.com/forums/nitrous-o...-3-spray.html?
Old 10-07-2011, 01:43 PM
dean85gt's Avatar
For an extra like 300 bucks to get an LQ9 arent the extra cubes worth it? Anyone have a hp comparison for a 5.3 vs a 6.0 with similar mods?
Quick Reply: aluminum 5.3 vs iron 6.0. Want to trap 124mph..
