Head/Cam/Lifter swap - pushrod length question
Old 10-09-2011, 04:04 PM
LS1MUNN's Avatar
Default Head/Cam/Lifter swap - pushrod length question
So I had a cam, lifters, push rods, roller rockers, and cam installed on my 180K stock engine. Subsequently I blew it up showing a mustang what my tail lights looked like. I bought another engine with 83K on it. If I swap lifters, cam, heads, rockers and all will the push rods still be the right length and the valve geometry still be correct?
Old 10-09-2011, 04:08 PM
Darkman's Avatar
Theoretically yes.
Old 10-09-2011, 04:34 PM
Restricted User
z99ls1's Avatar
same gaskets it shuld be
Old 10-09-2011, 06:39 PM
usmcz28's Avatar
I'd also make sure you have it tuned better before you keep blowing engines. WHo really won that race with the Mustang, I'd have to say he did as his is probably still driving.
Old 10-09-2011, 06:49 PM
cookba's Avatar
what blew? if something was off from the first build, you will blow another engine.
Old 10-09-2011, 08:17 PM
LS1MUNN's Avatar
#6 rod is spun.
Old 10-09-2011, 08:38 PM
LS1MUNN's Avatar
about an 1/16" of slop in the rod bearing. It was kinda weird the the way it went down. I was cruising down the highway about 70mph, this mustang rolls up next to me and revs. I just drop my car from OD to D and floor it. Poor mustang was left sittin. I lifted as my spedo was indicating 130 and when I lifted the engine stalled. I put it in neutral and tried to get it to start. 4 or 5 tries it finally lights up again but this time its knockin.
