Ls1 cam and heads
Old 10-18-2011, 10:47 PM
MIKELMOTORCYCLE3398's Avatar
Default Ls1 cam and heads
I just bought a pair of 317 heads with new valve job and milled 30 off. Puttin a cam with a 236/242 duration and .580/.590 lift with 112LSA. Puttin it on my ls1 stocker block. I have pacesetter LT 3in ORY into a flow. Have stock 98 LS1 intake with whisper lid and TB bypass and screen deletion. Has stock 28lb injectors. Also 11.5lb ram flywheel. What should i be puttin down after L&G perfect tune?? Also i need pushrod length recomendations and would i be ok with a single behive .595 lift spring or... Please fill me in. Also what head gaskets are best for the price
