Best ms4 setup?
Old 10-22-2011, 04:10 AM
408sharkmaro's Avatar
Default Best ms4 setup?
Hey guys I have a 02 z28 6spd with a ms4, ported tb, ls6 heads, ls6 intake, lt straight pipe, stock rear gears , stock fuel injectors, it currently makes 435 hp 416 tq, my question is what else can I do to get more out of this cam?
Old 10-22-2011, 04:15 AM
lemons12's Avatar
A **** ton.
FAST intake/tb setup
Chrs1313 ram air
1 7/8 headers
410s or lower
Set of heads, compression will play a the roll in how cams that size perform
That's a start
If you didn't want to spend money or go max effort, you picked the wrong cam. Max effort cams require max effort everything to work the way they should.
Old 10-22-2011, 05:15 AM
Captain Double Post
BOBS99SS's Avatar
^ agree, lemons i agree with you alot, honest your a smart guy and always give out good info,
Old 10-22-2011, 05:21 AM
Captain Double Post
BOBS99SS's Avatar
how high did you guys take it up to on the dyno? i would also say injectors would also be a good move,
Old 10-22-2011, 05:26 AM
lemons12's Avatar
Thanks man.
-Research
-Common sense
-Experience
A small potion of each of those go a long way.
Old 10-22-2011, 03:30 PM
What's a good pair of heads? And yea I'm getting 410 and bigger injectors soon
Old 10-22-2011, 04:40 PM
2QUIK4U's Avatar
AI, TFS, or AFR, would be my choice for heads.
Old 10-22-2011, 04:49 PM
DaFireMan's Avatar
Originally Posted by lemons12
A **** ton.
Chrs1313 ram air
1 7/8 headers
410s or lower
That's a start
Great info, Dont forget the little stuff like a good flowing Ypipe with the headers(or Y merge), injectors also!
Old 10-22-2011, 09:08 PM
Thanks for the good info guys!
Old 10-24-2011, 02:05 AM
Blk98Vert's Avatar
Not just 1 7/8s headers but ones with a merge spike and HVMC. I would also do true duals, your midrange will thank you.
Old 10-24-2011, 02:06 AM
lemons12's Avatar
Something to help with compression.
I would talk to ai about some 243s personally.
Old 10-24-2011, 02:09 AM
Blk98Vert's Avatar
Id call AI, AFR and TSP for heads definitely
Old 10-24-2011, 02:16 AM
lemons12's Avatar
Flycutting would be a good decision as well.
Old 10-24-2011, 05:10 PM
fatmat80's Avatar
You bought their cam I would definately call TSP and take a look at their PRC 215s. They can custom build you a set that will allow for max compression at a safe pvc.
Old 10-25-2011, 04:02 PM
Captain Double Post
BOBS99SS's Avatar
If your going to go with tsp look into the prc227 heads
