build a 250,000 mile engine
in a few days i will know if im going to buy a good deal on a 99 ta, they must have drove it every single day because it has 250,000 owner says orig engine and trans with no problems.....
but for hypothetical reasons am i smokin crack to want to tear the engine out and build it over the winter? new bearing all the way around, new rod bolts, arp main studs, cam,springs,lifters, push rods, maybe heads along with bolt ons.
point being, should i not trust the block or pistons
or if it the cylinders have wear in them and it has to be bored out
safe or no
safe or no
If you're fine with the current power, then just ride this thing until it breaks. Then do a full rebuild.
The following users liked this post:
JORGE (07-27-2021)
250k is a lot of miles and that engine has to be tired. If you have the money I would pull the motor out and tear it down. Have the bores checked as well reason being is that ls1 pistons already fit a tad loose in the block (which is what causes pistons slap) so chances are if the motor is severely worn then you may be better off getting new pistons and boring the block .010 over to get the bores round again.
If the bores check out fine then just re-ring it and put her back together with new bearings and a valvejob.
Btw the 99-02 blocks can only tolerate a .010 overbore while 98's will only take a hone so if for whatever reason it need more than a .010 over bore then make a nice coffee table with it and get a new block. lol
in short:
point being IS to make power.. not a stock rebuild.
point of question is about block/crank/maybe piston reuse or throw away.
i wanted to get opinions on weather i could/should build an engine simply because of the fact its high mileage
Sorry if I didn't understand your question. Are you talking about modding it or completely rebuilding it or asking if you should rebuild it?
If it has good compression and oil pressure I'd mod it. However I would replace the oil pump and timing chain as a precautionary measure. I wouldn't trust either with that kind of mileage.
The crank and rods should be just fine, I'd do a valvejob on the heads to get them up to snuff and then just put new bearings in it providing the crank looks good, and run her hard!
One other thing I will suggest is that if you are putting a cam in and will be spinning the motor higher than 6200 is rod bolts. You can get katech ones that are 200 for a set and they just swap out or you can pick up a set of arp's which are about 80 bucks but the rods will need to be line honed to ensure they are perfectly round for the arp's. Its your choice in the end but the stock bolts are hit and miss about 6700
im buying the car cause ive been waiting to pick one up to build into a nice ground pounder and its almost winter here where i am so why wait?
as for the rod bolts, why does arp have to be line bored and the other dont?
The ARP's don't "have" to be honed out .002" but they need to be checked for size and roundness with the bolts torqued in the rods . Skoggin Dickey has the ARP's for about $70 . The clamping force of the ARP's is greater than the stock bolts so they do distort the big end of the rods some more than others . The Katechs are designed with a certain type of metal that is able to basically equal the stock clamping force but be stronger than the stock bolts at the same time . You're choice . BTW just FYI in case the machine shop does'nt know about LS1's , the norm is to hone the LS rods out .002" and Clevite makes rod bearings that are standard size ID but .002" larger OD for such cases . Finding a machine shop competent with LS based engines could prove difficult depending on where You're located . Good luck
a local guy around here just bought a 200,000 mile lq4 from the junk yard and hes slappin a t76 on it and is gonna run 10lbs to it and see how long it lasts. its not goin in a race car, hes putting in his 69? impala convertible with a 4 speed. he tore it down and checked ring gap as well as the bearings and said it all looked good for the amount of miles. then again this guy is all about budget builds, hes the only guy i know that can take a 150,000 mile truck 350 from the junk yard, slap twin hair dryers on it and run high 9s with it in the 1/4mile in a 88 trans am GTA, ill see if i cant find the car craft issue of his trans am
edit: found it check out this guys build.
http://www.carcraft.com/featuredvehi...ird/index.html
dont mean to hijack this thread just thought id show ya that a high milage engine isnt something to be to terribly afraid of... at least he isnt hahaha
i picked up the car the other day and it seems well taken care of the car still seems to have its power and not tired engine
yes true i did make up my mind about building the engine, i just wanted to pick some brains and see what i can find out, since this is my first ls style engine build
but i have had my questions answered thanks everyone
Just want to add that I have 230K on mine now with orig. engine and trans-- no probs. Valve covers have never been off lol. Only ever changed one water pump and one alternator. As for the rest of the powertain I have had a fuel pump, rear wheel bearing, and clutch pilot bearing fail. That rounds out ALL the maintenance I have EVER done powertrain-wise. Hell, the only other thing was I soldered some cold joint in the "BCM" to fix intermittent radio/power window issues.
