YT rocker vs comp rockers??
I want to get new rockers for my car for some security and to see if I can get more power out of my set-up. I want to know which you guys would prefer. I'm kinda liking the comp ones with the guide plates and everything. Just want to see which would be more benificial.
I think J2K are Jessels. Not sure though. If they are then they are shaft mounted and if they are adjustable then they need valve cover spacers. The Comp Cam Pro Magnums are adjustable. They are not shaft mounted, they are stud mounted and they have the needle bearings like the stock ones.
Supposedly on the driver side baffle in the valve cover needs some grinding for rocker clearance of the CC Pro Magnums. Since I have the LS6 PCV mod I my driver side valve cover is sealed and I don't need the baffle anyway.
Don't forget that with the CC Pro Mags you also have the added expense of hardened pushrods which are required when using guide plates because the stock pushrods can't handle the gauling the guide plates cause on the sides of the pushrods. That having been said the CC Pro Mags are very high quality and are adjustable and don't require rocker cover spacers even if you do have to pay extra for a set of hardened pushrods.
If you change cam lift or rocker ration you need to check PtV clearance via valve drop method or the heads off clay method. There is a way to check the lift effect of rocker ratio changes but I don't have the equation in front of me. If I come across it I will post it.
Originally Posted by CamSS00
I already have hardened pushrods. I want to know more about the 7:5 having problems with the high lift cams..
Crane has a fully adjustable 1.7 rocker like their 1.8 that fits with no alteration of the covers and comes with hardened pushrods and guide plates. They are also sold under the VHP name and are at that site for 639 or so for the kit. They weigh less than the over weight YT's and are FULLY adjustable.
Good luck
Good luck
Originally Posted by 4thGENRETARD
Anything over .550 lift and you can forget all ratios except stock 1.70
