1998 Z28 ReBuild ( heads up ) - LS1TECH
Thread Tools Search this Thread
Old 11-12-2011, 12:44 AM   #1
stoning_volcom's Avatar
Default 1998 Z28 ReBuild ( heads up )
Hi there gents, my name is evan, lil info i was swapping a ls1 4l60e into a 90 firebird my wife got really ill and no i have to simplify. so i am going with a 1998 camaro z28 t56. the car has a tick in the top half so i expect it to be a lifter or somwhere along those lines.
here is what i plan on doing.
243 or 317's
ls6 valve springs
valve job a lil porting
all new gaskets
arp headbolts
and a rebuilt bottum end that i have sitting in my garage which consistes of
stock internals ,clevite bearings, moly rings, and arp rod bolts, new melling oil pump.
I go to pick up the car on this coming thursday. So as soon as i get it ill post pics then start the tear down. let me no i got a couple questions that i would like to be answered.
1st: Which way is best to pull the motor, from top, or lifting car over motor? (if i do end up lifting camaro is there a thread that walks you through it?)
2nd: what heads should i go with?
3rd: What headers are the cheapest but yet still good headers?
Thanks, E!
stoning_volcom is offline   Reply With Quote
Old 11-12-2011, 12:48 AM   #2
tt383lt1's Avatar
pull the engine threw the top for sure. and i run some long tube headers
tt383lt1 is offline   Reply With Quote
Old 11-12-2011, 01:12 AM   #3
Quote:
what brand?
Old 11-12-2011, 01:32 AM   #4
Dirty Vegas's Avatar
Out the bottom is the easiest if you have the right tools.
I'm running OBX headers and they have been flawless thus far (2 seasons).
Dirty Vegas is offline   Reply With Quote
Old 11-12-2011, 03:23 AM   #5
The top, 243s, and pacesetter.
ls1ya is offline   Reply With Quote
Old 11-12-2011, 04:55 AM   #6
camarodude87's Avatar
AI 243's
camarodude87 is offline   Reply With Quote
Old 11-19-2011, 12:01 AM   #7
Cool
So i bought the car,...... thought it was a lifter till it threw a rod through the block. so rebuild is in order. here is the deal
new ls1 block
new ls1 crank
cp pistons
eagle rods
new ported tsp heads (unsure right now)
new fbody oil pan kit
here are some pics of the car, but tranny needs rebuilt as well so.
Old 11-19-2011, 12:12 AM   #8
bww3588's Avatar
Bottom is easiest as long as you have a way to lift the car. I used a come a long hooked to the rafters of the garage and just rolled the entire k member out engine trans and all. 2 hrs from the time I drove it in the garage and rolled it back out onto the trailer.
bww3588 is offline   Reply With Quote
Old 11-19-2011, 03:36 AM   #9
Quote:
k well i got a car lift and that will work....... so ill figure it out. so any info or threads i should read??
Old 11-19-2011, 09:56 AM   #10
bww3588's Avatar
http://m.ls1tech.com/forums/showthread.php?t=857641
I also have a good book that details it. I'll find it and let you know
Old 11-20-2011, 02:51 PM   #11
so i got pics to post later of the damage so it is exciting
Related Topics
Thread Thread Starter Forum Replies Last Post
1998 Camaro-LQ9-Turbo Driver2 Vehicle Classifieds 2 12-03-2015 07:30 AM
Making My Own Cam ......Help if you can, no Rookies lil john Generation IV Internal Engine 21 03-12-2015 11:37 PM
Ls1 to lq4 Conv_z28_camaro Generation III Internal Engine 5 01-20-2015 07:40 PM
Another 6.0 Fox Body 6.0L mustang philly Conversions & Hybrids 67 10-12-2014 06:45 PM
What else do i need for a nitrous install?? pewtered'Z Nitrous Oxide 4 09-03-2014 03:32 PM
Tags
1998, 1999, 98, camaro, engine, heads, ls1, oil, pan, rebuild, rebuilding, removal, transmission, v6, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
