Eagle Cranks and Pilot Bearing??
Just finishing up my 408 and I found out the stock pilot bearing does not fit right, slides in and out by hand.. Anyone heard of this or know what pilot bearing to use for the eagle crank??
edit: apparently eagle says that it should use the stock pilot bearing, but pilot bearings have different tolerances and some will fit better than others..hmmm
Tried a new pilot bearing as suggested by Eagle and it fits exactly the same way.. I can push it in with my thumb and pull it out w/ my pinkie.. too many suprizes for me
Worst part it, its a complete long block now b/c Eagle said it work..
btw this is the same crank that had to clearanced once already..
anyone have any ideas?
Originally Posted by PK 01somWS6
what would be the possible result of a pilot bearing fitting as I have described if finalized in a running vehicle?
Super Moderator
Yep...this is the same crank I posted about earlier that had to have the counterweights shaved down to clear the piston skirts Peter, if I would have thought of it, I would have checked it before sending teh short blovk down to you. We will get it sorted out. Call Steve at Kammers directly and ask him to contact Eagle for a new crank. I will walk you through pulling the crank and installing the other one.
Well heres what Allen at Eagle told me directly this afternoon...
The crank was honed .001 too much and that lock tite as well as possibly dinging the end of the crank would solve the problem.. I'm giving the lock tite a try only because he gave me his word that would solve the problem.. I will let it sit and check it out tomorrow afternoon.. A friend of mine with lots of experience from a local shop will check it out and we'll go from there. It's been a real pain so far..
BTW steve said to give it a try as well.. Not too mention a few others from well known shops..
The eagle crank is not hollow so atleast no needle bearings or pieces of the bearing can enter the crank/motor... thats good I guess..
Yeah I just went to change my pilot bearing and i had the same prob on my 408 stroker w/ eagle crank. I called them and they said to get the outer diameter of the bearing knurled. what a pain in the ****!!!!
