Rebuild + Break In
Rebuild + Break In
I am having my engine rebuilt with new pistons and rods for lower compression and better forged internals for turbo app. It is almost complete and I was speaking with the guy doing the rebuild about when it is all done and I mentioned breaking it in before putting the turbo on and he said there is no break in required. He said we should put the turbo on while it is there and drive it straight to the place to have it tuned at whatever boost I want to ultimately run(approx 10-12)
Does anyone object to this, should it be broken in first? If so why?
THanks
THanks
With any new setup you need to break it in. You need to seat the new rings into your hopefully brand new honed block. If you don't you will cause premature wear. Just my feeling, always did it to my new cars, I could be wrong but i've always did it that way.
Dumb Ass Vette Moderator
Originally Posted by StevieZ
Rings seat best under PRESSURE . Run the car in 4th (3rd if A4) from 2500 rpm to about 4500 rpm under full throttle. Do this 2 or 3 times are your rings wil be seated in the best way .
was speaking to a friend and he said he has heard to run regular oil for 500-1000 miles with low boost and then change back to synthetic, up the boost, and tune. Any ideas?
