At what point do lifters need to be upgraded
Motorboater
i replaced mine when i did my first heads/cam swap at about 30K. I just got federal mogul factory type replacements as I recall, not comp r's or anything. only did it just to be on the safe side and because i'd been running a hotcam in the car since like 16K miles and beating the **** out of it constantly.
Originally Posted by StevieZ
Not necessarily....... I just bought a brand new set WITH the plastic retainers for $130
Thanks,
Chris
try this thread...
basically...it tells you when the stock lifters will give way...
although I have seen a few mild cams colapse a lifter at the track(like a 224/224 .581/.581)
https://ls1tech.com/forums/showthrea...lifter+colapse
its basically based on the seated pressure...
figure yours out...then decide for yourself if it is too much pressure for your piece of mind....
I'm doing mine when I do my heads...since I will have easy acess to them at that time.
Don't the heads have to be pulled to change the lifters though? I was planning on doing a T-rex cam swap here soon and I HEARD that the heads have to be pulled..... I have never worked with the cams on an ls1 just the old SBC's
Josh S.
Josh S.
