Texas Speed 224R 581/581 Cam
Does anyone know if this cam has an aggresive ramp on it? I've beat my head aginst the wall with the push rod length, and I know I have that correct, but it still sounds like a sewing machine. It did quite down some after I figured out the push rods.
I've read a lot about how LT Headers and a FAST intake can also add to all the valve train noise as well, still knowing all that, it still bugs me.
I know, I know, If I want it quite, leave it stock right? Or like one person told me, go buy a stock C6 ZO6 w 505hp and leave it alone.
Anyone with this same cam, please chime in.
I know on my comp 224 with the same lift its actually pretty quiet...7.375 pushrods. Lt headers do have a lot of chatter and tinging to them. Did you change lifters? Maybe they arent pumping up fully?
im running a 224/230 comp cam xer273 and i have a little sewing machine noise, but thats too be expected with the aggressive ramp rates of these bigger cams...i used 7.4 pushrods with stock 243s and i have been advised to use 7.375, but my motor is running good so id hate to change it...only fix would be to run an eps cam bc they are alot easier on the valvetrain for sure
I'm running TEA Stage 1 heads, LS7 lifters and stock rockers.
I'm thinking about swaping out the Cam for one with a less aggressive ramp rate.
It's the exhaust lobes that make most of the noise, If you go with XE-R intake lobes and XE exhaust lobes the XE lobes will quiet it down, but a 224(xe-r)/224(xe) cam will make less power.
Now if you're willing to go up higher in lift you can have you cake and eat it too!
224(.609"xfi)/226(.605"lxl), or 223(.610"lsl)/226(.605"lxl)
FYI, there's no 224 lxl lobe, the next lower lobe duration is 222.
Don't buy any push rods until you measure first. Buy an Comp Cams push rod checker, then buy your push rods. No one can tell you what length push rods to use until you measure first.
I'm thinking about going with a EPS 224/226 Cam. They seem to be addressing the "sewing machine" issue with their Cams.
LS1Tech Premium Sponsor
This is the best advice anyone can give on pushrods!
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
