High CR cnc'd 241 vs cnc'd 243?
Old 01-13-2012, 09:44 PM
  #41
senicalj4579's Avatar
Originally Posted by Camaro99SS
I went with their "High Compression" 241 port. They told me on a h/c LS1 there's a ~8-12hp difference. The machine work is higher on the HCR 241 because they do more work in the combustion chamber and re-shape the valve angle to give the same PTV clearance as a stock 241 head. I'll have dyno results here shortly.
Jason
8-12 hp dosent really seem worth it to buy more heads. Cant wait to hear your results!
Old 01-15-2012, 01:48 PM
  #42
formerly twolow02fransen (2014-1-2)
02_Orange_D1SC's Avatar
Originally Posted by BIGDRAGON
Does anyone have a video sound clip of one of AI mild cam?
i have there 226/230 600/600 111lsa in my LQ4 with there 226 243 heads ill see if i can get video
Old 01-15-2012, 02:46 PM
  #43
BIGDRAGON's Avatar
That would be awesome! Since I'm gattering all my parts before I get my H/C from AI. I know that the thermostat needs to be change to 160 degrees do I need to change the housing or just the T-stat?
Old 01-15-2012, 04:15 PM
  #44
mac62989's Avatar
Who says you need to do that?
Old 01-15-2012, 04:51 PM
  #45
BIGDRAGON's Avatar
I've read somewhere here that the thermostat needs to be at 160 degrees when doing H/C.
Old 01-15-2012, 05:21 PM
  #46
A.R. Shale Targa's Avatar
An internal combustion engine (especially all aluminum) makes optimum power
at between 188-192 degrees coolant temp. Warren Johnson said so, nuff 4me
Old 01-16-2012, 09:41 PM
  #47
Camaro99SS's Avatar
No, it's not a bad idea for an old school iron block 350 with iron heads though. Even then you could still run a colder plug to keep detonation tendencies in check instead. My 99 had a 160 t-stat, and the highest numbers it made on the dyno were on the last run after letting it idle a few minutes to let it heat up to ~190.
Also, it has been shown that the cylinder walls wear less with the hotter t-stat. It's pretty small in the real world and probably won't translate into much of a difference in miles driven, but it's still measurable in extreme conditions.
Jason
Old 01-16-2012, 09:47 PM
  #48
I run the stock t stat. I like to keep the temps 190-200. With my fan settings it will run 194-203 most of the time in warmer weather. I wanna make sure oil and coolant get up in temp where they should be to burn off moisture and lube the best.
Still not sure what heads to go with hmmm.
Old 01-16-2012, 11:30 PM
  #49
Zmg00camaross's Avatar
Jason
Yeah I would be very interested in your results please post up.
Old 01-16-2012, 11:41 PM
  #50
01ssreda4's Avatar
Go with the 241s since you already have them.
Old 01-17-2012, 01:30 AM
  #51
whatsa347's Avatar
My question is does the higher compression cause any problems? I feel like you would get better gas mileage, no? I'd like to give the 241's a chance for my next build, and maybe an f11 or something along those lines, hell maybe even a tr224 and daily it all day. Never thought I'd see the day where a company could do such good work that it made people second guess the almighty 243's. Props to AI!
Old 01-17-2012, 05:07 AM
  #52
mark21742's Avatar
I run a stock 180 degree thermostat and my engine always sits between 194-198 whether its freezing out or 100 degress
Old 01-17-2012, 08:40 AM
  #53
BIGDRAGON's Avatar
That answer my question.
Old 01-17-2012, 09:10 AM
  #54
mark21742's Avatar
I've heard good snd bad things about going with a 160, but I never tried it myself since the 180 keeps mine at peak temp
Old 01-17-2012, 09:29 AM
  #55
mark21742's Avatar
As long as you don't go too high with your compression it will show gains in power and effeciency ....as long ad you can still pull full timing without knock.
To get close to yhe edge of compresdion you need to forget about static compression and look at dynamic compression and cranking psi....specially when you start to get bigger cams......8.5:1 dcr is about the max you can run on pump gas in "perfect" conditions (air temp, density, humidity). for example I'm running 12.5:1 scr, but since my intake valve doesn't close until 85degrees abdc I only have about 2.5" of effective compression stroke so my dcr comes out to 8.22:1 which is safe for pump gas under almost any condition with full timing and no knock.
I'm running a 255/263 .624/.624 115lsa cam....if I threw a smaller cam like a 224-228 in my motor I could never run pump gas and I'd have to run race gas to stop in from detonating.
Hope this helped
Old 01-17-2012, 01:37 PM
  #56
whatsa347's Avatar
Hope this helped
Helped alot, gracias
Old 01-17-2012, 08:19 PM
  #57
allna6's Avatar
I am not sure which would be better but you could buy these and do a test
https://ls1tech.com/forums/parts-cla...90-intake.html
Old 01-18-2012, 05:26 PM
  #58
heres the video i said i would post up and btw truck is untuned and this is a cold start http://youtu.be/PPa3THTDISE
Old 01-18-2012, 07:09 PM
  #59
BIGDRAGON's Avatar
That sounds sweet!!! Thanks for posting it.
Old 01-18-2012, 09:22 PM
  #60
no problem
Quick Reply: High CR cnc'd 241 vs cnc'd 243?
