Cylinder flex honing
Ok so whats the procedure for flexhoning an engine block? My guess is lube the flexhone and cylinder walls with engine oil and make 15-20 quicks passes up and down with the hone. Am i right?
flex hone doesnt even take off a significant enough of material to require a torque plate...its just to get a good cross hatch for rings to seal...no even close to taking off one thousandth of an inch, and if it is you are either using wrong grit, or making over 50 passes with the thing
