Just a little thought of NO2 after getting heads ported. JUST A thought.
Old 01-12-2012, 11:00 PM
1sicss's Avatar
Default Just a little thought of NO2 after getting heads ported. JUST A thought.
What would I need and like the title states it's a ponder right now.
Old 01-12-2012, 11:41 PM
sepsis's Avatar
You would need a nitrous kit and maybe a rev limiter.
Old 01-12-2012, 11:47 PM
TransAmcoupe98's Avatar
And a steering wheel with buttons that say NAWZ
Old 01-12-2012, 11:49 PM
kons02Z28's Avatar
do you have a cam already? That should be first
Old 01-12-2012, 11:52 PM
sepsis's Avatar
Mines gonna say "Go Baby Go!"
Old 01-13-2012, 12:20 AM
wildcamaro's Avatar
If it will be a nitrous specific motor I would run a colder spark plug and change to ring gaps to around 28 thousandths...also a cam would benefit you as well but is not neccesary...you also need a different tune to add more fuel to match the level of n20 your planning on throwing at it...good luck
Old 01-13-2012, 12:55 PM
95ONE's Avatar
Depends on the shot. 100 shot, don't even worry about it. (Wet shot after the MAF) I would certainly look into an electronic tps voltage / window switch. Makes nitrous pretty idiot proof.
Old 01-13-2012, 12:57 PM
95ONE's Avatar
I forgot to mention the manifold pressure monitoring computer that keeps your floorboard from popping up when pressure gets too high. As a matter of fact, buy 2 of them.. the BIG ones.
Old 01-13-2012, 01:01 PM
sepsis's Avatar
LOL
Old 01-13-2012, 01:27 PM
1sicss's Avatar
Thanks fellas for the quick and positive responses now now ya'll really got me thinking. I can see the future broken rear or tranny and a thrown rod. and yes it has the torquer II cam from tsp and in the works currently from landspeed ported and polished 799's with a 245cc intake. I know that's big for stock cubes but it gives me the oppurtunity for growth in the future maybe stroked if I can find a ls block to slowly work on.
Old 01-15-2012, 04:37 AM
kons02Z28's Avatar
dry kit is good to start with,bigger injectors,racetronix fuel pump,and one step colder plugs wouldn't be a bad idea either
