slack in timing chain
Old 01-19-2012, 04:07 PM
bradw18's Avatar
Default slack in timing chain
well just got my cam retaining plate in from texas speed and got it installed finally got to put my timing chain gear on and timing chain just to find out that theres a lot of slack in the timing chain. so much that the cam probally moves a few degrees before i takes up the slack in either direction.
my set up its a 1999 5.3 truck block bored 20 over
new v2 cam from texas speed
stock crank that was checked by a machine shop
hd timing set ordered off here
not sure if the parts are wrong
has anybody else had this same problem? this is my first ls build so im not sure if thats normal or what?
Old 01-19-2012, 05:21 PM
3rdCoastPowerSports's Avatar
slack in the chain for the most part is normal. im sure your fine. if you could post a video it would make it alot easier for us to help you determine weather its normal or not
Old 01-19-2012, 05:30 PM
Imstock2's Avatar
did you bolt it all the way up? I went with slp double roller and the chain seemed loose until I tighten the bolts to spec. Is this a stock chain? Who made the chain and was it used?
Old 01-19-2012, 05:57 PM
wildcamaro's Avatar
Yea when I did my cam swap I though "wow I'm glad I got a new timing chain" bc my old one had a little slack, but after putting new ls2 on it, the chain still had the same amount of slack
A little slack is normal though, but double and triple check everything else...did you install a new cam and crank gear? Same amount of teeth and same diameter as the old ones? It's worth checking...and make sure you get dot to dot one the gears
Old 01-19-2012, 08:38 PM
bradw18's Avatar
everything is new. and everything is torqued to spec. i guess im gonna put it togeather i messaged the guy i got it from and he said it was normal gm says there can be up to 3/8 inch play in the timing chain
Old 01-19-2012, 08:49 PM
bradw18's Avatar
timing chain video
Old 01-19-2012, 09:20 PM
RezinTexas's Avatar
That is WAY to much slack. Go to Autozone and pickup an LS2 chain for $40 or so.
Old 01-19-2012, 09:24 PM
mannyman84's Avatar
Autozone? No way man.
OP get an OE ls2 chain.
Old 01-19-2012, 09:33 PM
RezinTexas's Avatar
ok, try Oreilly's then. They sell Cloyes chains for cheap, they are OE supplier.
Old 01-19-2012, 09:38 PM
bradw18's Avatar
i bought it from a guy on here. its all new. with the billet cam sprocket. do i just need a new chain or what?
Old 01-19-2012, 09:40 PM
bradw18's Avatar
iv built a few motors and none of them has had this much slack in them. i dont think i like the idea of spraying a 250 on it with the chain like that. i already have a melling oil pump so double roller isnt an option i just want a single roller that dont have a lot of slack in it.
Old 01-19-2012, 09:52 PM
sic7camaro's Avatar
Originally Posted by bradw18
timing chain video
i have the same problem.i took out my ls2 chain for the billet sproket and hd chain,after checking the new chain it doesnt seem very hd to me.ill post pics of ls2 chain and so called hd chain
Old 01-19-2012, 09:57 PM
sic7camaro's Avatar
Hd ls2 chain on left oe ls2 on right.u be the judge
Old 01-19-2012, 10:23 PM
bradw18's Avatar
were did you order yours from? which chain you gonna run and do you still have a lot of slack in your chain? and did you still use the hd sprockets? i got mine from a member on here that was selling them for 72 shipped for the hd sets.
Old 01-19-2012, 10:25 PM
bradw18's Avatar
one on the left looks hardened.
Old 01-19-2012, 10:32 PM
sic7camaro's Avatar
i got it from same guy u got it from.still have slack on both chains.im gonna run the one i got new.and i did use th billet sprocket
Old 01-19-2012, 10:37 PM
bradw18's Avatar
same amount of slack on both chains ya think? so is it to much slack or do all ls1s have this much????? has these chains failed on anybody? iv got a lot of money tied up in my build. hoping this will be the last motor i put in my truck for a while.
JonCR96Z's Avatar
I've got the same slack in my chain (150k mile motor), but I just saw another (supposed 40k mile) with the same slack. It wouldn't hurt you to be tighter though.
Old 01-19-2012, 10:38 PM
seems like more slack than i have seen but to be honest i have taken apart several LS2's that have near that much slack. then again these motors had 119k and 155k on them. I would just buy a dampener and a new stock LS2 chain and call it a day.
Old 01-19-2012, 10:40 PM
m6speed's Avatar
i got mine from yank in the deal they are running in the fs section, mine has every bit as much slack as yours does, you can always get the ls2 damper, or the c5r chain from katech
Quick Reply: slack in timing chain
