Custom Cam People Come Inside!
Old 01-20-2012, 06:51 AM
DoggyB22's Avatar
Default Custom Cam People Come Inside!
For those of you who have a custom cam for your ls1. Post up the specs of it, how much hp/tq you made with it, your other mods, what you ran at the track with it, & who made it? I plan on getting a cam soon with some ls6 heads & I'm deciding if I want a custom cam or not. Thanks
Old 01-20-2012, 07:31 AM
96gtdan's Avatar
Old setup LS6 2.5 heads, 233/339 598/604 on 113 centerline stock 2007 lq4. Had Fast 102 intake with Ls2 90mm throttle body and Dynatech 1 3/4 headers. With Performa Built level2 4l60 Yank SS 4000 thru 8.8 rearend with 3.73s. Race weight of 3360 ran best of 11.23 at 121 1.55 60ft. This was at 3100 ft Da.
Old 01-20-2012, 08:52 AM
mark21742's Avatar
Not custom, but off the shelf. In my ls1 I ran a 230/224 .595/.595 112lsa 2,800 rpm stall(felt almost stock with more power everywhere in the stock rpm range) then jumped up to a 238/242 .595/.595 112lsa very lopey, 3,800 stall, and very aggressive at higher rpms pulled hard as hell up to my 6,500 rpm fuel cut.
Seems most heads/cam guys like low 230's duration cams for all around best performance.
Old 01-21-2012, 01:11 PM
DoggyB22's Avatar
Alright sweet so maybe something in the mid-high 230 range...
Old 01-21-2012, 05:20 PM
Old School Heavy
speedtigger's Avatar
I went with a 226/234 on 110 LSA with EPS/LSL lobes. The best pass so far is 7.25 @ 96.53 in the 1/8th - this is 11.37 @ 119 in the 1/4 in my car. If I did it again, I would go 230/234 on 110 LSA.
Old 01-21-2012, 05:44 PM
lemons12's Avatar
226/228 .588 .588 114
Hand ported 317s/ls6 intake/exhaust/etc... Budget setup.
7.30s@94.5.. I was barely spinning out of the hole with 1.50-1.53 short times. DA was 2000-2000+ and had a nitrous tune in the car. 3500#
Custom grind is the way to go.
Old 01-21-2012, 07:22 PM
SOMbitch's Avatar
Asking #'s is pointless Because I have seen so many bogus claims & even dyno sheets on here... Same with some guys and their times..... Go drive some cammed cars if you can and hang around the track to see what runs...
Old 01-21-2012, 07:36 PM
Old School Heavy
HA!
This is why I have videos and timeslips in my signature. I am surprised I do not see more people doing that.
Old 01-21-2012, 09:33 PM
SOMbitch's Avatar
Originally Posted by speedtigger
HA!
LOL I wasn't referring to you. There is a reason more don't do it Really like your car BTW you have done a nice job on it
Old 01-21-2012, 10:36 PM
studderin's Avatar
23x24x .650+
10.6 @ 129 441whp NA LS1 stock heads t56, S60
Old 01-22-2012, 12:44 AM
mark21742's Avatar
The reason you don't see one in mine is because it has never been on a dyno....honestly I'm kind of afraid to put it on a dyno and be disappointed lol
Old 01-22-2012, 12:45 AM
mark21742's Avatar
Oh, and reading back through I had a typo....was a 220/224 cam, not a 230/224
Old 01-22-2012, 02:58 AM
lemons12's Avatar
Mine was only making 377Rwhp on those passes I posted.
Old 01-22-2012, 09:41 AM
NVR_SPDS's Avatar
Pat G spec'd EPS 226/230 .613/.608 113+1 LSA
Unported, Milled 799s
PRC .675 EHT Springs
SLP Lid/MAF
Ported TB
Stock LS6 Intake
SLP L/Ts w/Hi-flows
Magnaflow Catback
Monster Clutch, built T56, Stock 10 Bolt
411rwhp/390rwtq on a Dynapack Dyno.
This is a pretty mild cam, with minimal lope, but is an easy drive, and is pretty torquey all over the place.
Old 01-22-2012, 10:30 PM
SuperSlow02's Avatar
235/243 .623/.623 lsl, stock heads, ls6 intake. 5kstall with a th400/9", 3500lbs est. went 7.2s@94 1.58 60ft. No Dyno #
Old 01-22-2012, 11:18 PM
wildcamaro's Avatar
Who tuned your car NVR? Or should I say what dyno was used lol....I have damn near the same stuff, and while I wanna be over 400 at wheels I don't quite think I'm there, but maybe it's bc you have a stick car
Old 01-23-2012, 12:57 PM
99 Blue Bird's Avatar
Synergy Motorsports. They use a dynapak dyno. So the numbers are a little higher then if tuned on a regular wheel dyno like a dyno jet. But the tune is supposed to be more spot on with a dynapak. And Synergy is good at what they do.
Old 01-23-2012, 01:36 PM
'02 WS6's Avatar
227/235 .614/.621 112+2 LSL lobes, PatG specd and ordered thru EPS with Geoff doing final spec. Ran with ported/milled 799s and ported FAST 92. Never dynod, but my tuner estimated around 470rwhp based on its 11.60s 1/4 time with 1.80 60ft. Currently is beating 500rwhp cars with top end swapped into a forged 376, but no new dyno numbers.
Old 01-23-2012, 05:52 PM
butler's Avatar
Lq9 408 all forged 236/248 eps cam. .617 lift I believe. 1991 foxbody turbo 400 carbed. 10.25 at 130.80 n/a. 3.89 moser spool.
Old 01-23-2012, 07:20 PM
Old School Heavy
Thank you! I really like your avatars.
