Best place to get AFR 210 heads / cam combo ?
Old 01-20-2012, 04:02 PM
JoeDirt's Avatar
Default Best place to get AFR 210 heads / cam combo ?
I would like to buy a complete heads cam combo from a proven vendor if possible. Will be paired with LG Motorsports pro long tubes ( off road ) on c5 z06.
Old 01-20-2012, 10:00 PM
mike c.'s Avatar
Vengeance racing is a great shop,lots of help when you need it. However,Pat G does custom cams. He has done two for me and each time i made a gain over the cams i removed. Vengeance for heads and parts,Pat G for a cam. Goodluck. By the way,Great choice in the heads you want to buy.
Old 01-20-2012, 11:26 PM
01_SuperSlow's Avatar
Vengeance racing doesn't sell AFR's.
Old 01-21-2012, 09:24 AM
Camaro99SS's Avatar
For cam selection with AFR's go straight through Tony Mamo. As the lead designer, no one knows how to better spec a cam for those than him, period. The only other source for this would be Pat. G because he's had several AFR combos, both with their earlier and latest designs and knows what works best. The high airspeed and exhaust flow require a bit of a different approach than most.
Jason
Old 01-21-2012, 09:29 AM
NVR_SPDS's Avatar
Yup, go straight to the source, and talk to Tony Mamo directly. You can shoot him a PM on here, or call him up and he can go over all your options, and get you exactly what you need for your setup.
Old 01-21-2012, 09:30 AM
wildcamaro's Avatar
Yea talk to mamo if you are going with afr heads
Old 01-21-2012, 09:31 AM
Rise of the Phoenix's Avatar
Jason
^^^ Great advice right there. No one knows AFR heads better than Tony, so he's the obvious choice in regards to the cam. Plus, you want a one stop shop, well, then go through Tony.
Old 01-22-2012, 02:36 PM
Rickenbackerman's Avatar
Tony's spec-ing my entire top end package right now - heads/intake/TB/cam, rockers, gaskets... the list goes on and on. He's a literal "one-stop shop". Shoot him a PM.
Old 01-22-2012, 09:50 PM
JoeDirt's Avatar
I will do that. Thanks guys !!
Quick Reply: Best place to get AFR 210 heads / cam combo ?
