Is this block ok?
Is this block ok?
I took some pics. Engine spun a bearing which i think can be line bored out, then run an oversized bearing. I have attached pic, does this cap look ok?
However i was noticing in the head bolt where the dowl goes at the back of the block, there is this hole. It looks like possibly the machining for the tranny bolt (which is the hole i'm using on the engine stand) got into the head bolt area. Is this okay? is it gonna leak coolant or have issues?
Reason i ask is this cylinder also had coolant in the cylinder.
