Oil psi please help
Oil psi please help
Ok i got my motor rebuilt 6 months back. I my problem is when i got the motor put in and ran 10-40w Quacker state oil at cold start the psi would be a 50 and at hot it would be at 16 psi .... I have the ls6 oil pump. I moved up to 20-50 Quacker state oil at cold start its a 60+ and at warm its at 30..... MY PROBLEM IS WHEN I GO WOT THE PSI DONT SEEM TO GO PASS 45...... I have a fram oil filter and the quaker state oil.... I replaced the ls6 oil pump with a melling pump.......... Is there any thing I can do to just atlest get me 60 psi at WOT
first thing to do, would be to call the builder, and ask them what oil you should be running.
the only chevy's i've built have been the 454 in the car in my sig.....that ran 80 cold idle, 35 operating temp idle, and was around 80 going through the traps with the throttle firewalled.
i built a small block 400 for my old 70 c-10 4x4. that ran about 65 cold, in the 30's warm idle, and avg. around 45-55 cruising down the highway.
most all of the fords i've built have been similar.
again...most important thing. find out what the builder recommends.
check the o ring into the pump as mentioned also check the retaining plate on the cam and make sure the seal on it isn't leaking oil out of the galleys also check the barbel plug and make sure its not broken and is sealing........it could possibly be the clearance on the bottom end causing it if it was built very loose......anything over .0032ish on rods and mains and the engine could start to exhibit these symptoms espicall if oil flow volume isnt there.......however keep in mind the myth that you need crazy oil pressure is not true......at 8000rpm i have mine at 55psi and after numerous inspections the engine and bearings look fantastic after heavy usage.......higher oil pressure than necesary is power loss.......
Def check that oring! I know there are different colors too...as far as oil I have heard nothing but bad things about Quaker state! I know oil is a person to person preference but everyone I know call it Quaker sludge! I'm sure the oil brand has nothin to do with oil pressure but I figured I'd tell you what I've heard! Also seen some testing that was less then favorable for Quaker state.
Your Fram filter could be bad also, they are known to clooapse and cause psi issues, and why are you running quaker state? When I bought my 98 the oil in it was cheap bulk 10W 40 and a no name filter. When hot it was around 20 psi idling and around 30 cruising. As soon as i switched to Mobil 1 I went to 30 idle and over 40 cruising. So try a change
what oil should i run and what filter . i live in the bottem part of texas so its hot most of the time ..... I dont want to run think oil simply cause i think the psi will drop more,, when i dropped the motor back it the car i made sure the back barbell was not broken and made sure it was seal, made sure the plug in the back and front was not damage, o-ring is seal right.... Im more that sure it a clearance issue with the rods>>> ANYTHING WILL HELP
