piston question
Old 01-28-2012, 01:27 PM
combs_425's Avatar
Default piston question
I am tring to price a turbo motor together but i am kinda clueless about witch pistons i would want to use. i know that i want to use dished. I am not too sure as far as what cc to go with. I want to run about 10-15 psi and i have a goal of 700 rwhp thru a t56. thanks
Old 01-28-2012, 10:12 PM
combs_425's Avatar
Old 01-29-2012, 02:24 AM
dkrowner's Avatar
whats the C.C. of the heads and what block are they going into?
Old 01-29-2012, 08:15 AM
combs_425's Avatar
it will be a 383 LS1 and 317s
Old 01-30-2012, 10:31 AM
combs_425's Avatar
so i guess if i run a smaller cc head, i would need a bigger cc pistion to get the cr down. Does that sound about right?
Old 01-30-2012, 05:07 PM
dkrowner's Avatar
i'm a firm believer in using small cc heads in getting your targeted cr with the piston choice.is this a street car or strip car?
Old 01-31-2012, 01:44 AM
combs_425's Avatar
mostly street but i do want to take it to the track!
Old 02-02-2012, 11:46 AM
combs_425's Avatar
so to get to my target hp what would I need to run?
Old 02-03-2012, 05:06 AM
dkrowner's Avatar
that's a loaded question as a bunch of things come into play, C.C. of heads + gasket thickness + cylinder bore + piston shape = CR.i would talk/email with the company who's pistons you plan on using or the shop your buying them from.i like CP & wiseco myself,and don't forget to tell them its for a boosted engine
