Would more lift help??
I love the GMPP asa cam, just thinkin i need more lift because i have ported 806 heads that flow 286cfm on my 98. Anyone heard of 226/236 .590 lift???? Without a custom grind??Plus or minus a little on the lift too
get a cam with LSL lobes (LSR cams from Comp Cams) they have lifts between .614-.624 my cam is close to what you want, it is:
227/235 .614/.621 113LSA. this thing is a beast on the street and a monster at the track. i still get 28+mpg on the highway at the end of the day.
If you went with the SLP 1.85 rockers that should put your lift at .571", or a new TSP custom grind cam with 226(.585") XER intake lobes and 236(.578")XE lobes, and go with the same 110 LSA, and a 110 ICL if you want it the same.
http://www.texas-speed.com/p-161-com...-camshaft.aspx
