Pushrod length?
Old 02-01-2012, 05:31 PM
Ph.D. in HUBRIS
custm2500's Avatar
Default Pushrod length?
I have an LQ9 built into a 408 it will have stock 317 heads on it and factory rockers. If it matters the cam is 23x 24x /.62x and .63x. I will have a stock thickness gasket also.
Can anyone tell me what length pushrod I will need or do I have to assemble it then check length?
Old 02-01-2012, 05:35 PM
salemetro's Avatar
Yep...to do it correctly, you need to assemble...then measure....all of them.
Old 02-01-2012, 05:46 PM
Ph.D. in HUBRIS
custm2500's Avatar
Can i buy a measument tool cheap or does someone have one they will rent to me when the time comes? I don't know how much they are.
Old 02-01-2012, 05:52 PM
Ph.D. in HUBRIS
custm2500's Avatar
Seems like they are only $20. The pushrods should be in the 7" area. So this will work?
http://www.ebay.com/itm/COMP-HIGH-HI...sories&vxp=mtr
Thanks. Also is one enough or do I need two?
Old 02-01-2012, 06:02 PM
salemetro's Avatar
That'll do ya! only need 1.
