Anyone running or know much about the FTI Hellfire cam?
Old 02-03-2012, 09:57 AM
Rise of the Phoenix's Avatar
Default Anyone running or know much about the FTI Hellfire cam?
Specs are 229/236 111 LSA - .630 - .630
FTI website says a 2000 F-Body with ETP Heads and this cam made 460 rwhp. Just curious if anyone on here is running this cam and can chime in.
Old 02-03-2012, 10:11 AM
ABQ99TA's Avatar
I don't run this cam but I believe it's an Ed Curtis grind so it should work well.
Old 02-03-2012, 10:42 AM
outkast6991's Avatar
I was running a version of the hellfire from Ed. Mine was 230/242 .633 .622 on 110lsa. It made 465/435 with stock runner 243's on a 6.0 short block. The intake lobe was very aggressive and killed a set of PAC 1518's in less than 8000 miles
Old 02-03-2012, 12:03 PM
Yes, it is most definatley an Ed Curtis cam.
Old 02-03-2012, 12:05 PM
When you say you were running a version of the Hellfire cam, does that mean your cam was using the same lobe design/profile as the Hellfire cam. I'm pretty familiar with Ed Curtis cams and know he has several different "profiles" or designs that use the same family of lobes.
Old 02-03-2012, 12:46 PM
whatsa347's Avatar
You'll probably get better responses from the gto forums, lots of people run ed's cams over there.
Quick Reply: Anyone running or know much about the FTI Hellfire cam?
