408 iron block info wanted
Old 03-18-2004, 10:52 PM
hillis's Avatar
Post 408 iron block info wanted
I am building a 408 iron block stroker with a 4.03 bore. What head gaskets are you guys using? I was planning on using a late model metal gasket off a 6.0 truck. Is there a better way to go?
Also I looked for some kind of notch on all of the pistons for reluctor wheel clearance and cannot find any. I have the lunati stroker kit and want to make sure this is a successful install. The parts in the kit are very impressive and come balanced with all the weights written for you. Should I have the balancing checked or just put it together? I know that not all stroker kits are created equal and have seen on the forums all the problems there are. I hope that I bought the right kit and would appreciate any info from others that have used this setup. Thanks.
Old 03-18-2004, 10:55 PM
fast 98 C5's Avatar
Had one just like it, awsome kit, I would spend the money and have the weight double checked just to be sure.
Old 03-18-2004, 11:50 PM
hillis's Avatar
It looks like you have even more cubic inches now. How much do you dyno with that setup? Also on your 408 do you know what head gaskets were used and how much did it dyno?
Old 03-18-2004, 11:55 PM
Spinmonster's Avatar
Use cometic MLS gaskets. www.cometic.com
Old 03-18-2004, 11:56 PM
fast 98 C5's Avatar
Yea stepped up on C.I. now. I not sure about the gaskets, I think fel pro's. I'm a A4 I was in the 450 range with the 408. 6.0 heads. Good luck and have fun.
Old 03-19-2004, 08:06 PM
hillis's Avatar
Thumbs down
Cometic does not list a ls1 head gasket with a 4.03 bore. Thanks for trying to **** me up.
Old 03-19-2004, 11:36 PM
GueSS Who's Avatar
You have to call cometic to get a 4.03 bore gsk. They might have them in stock but I doubt it. Hands down the best gsk IMO.
Old 03-19-2004, 11:41 PM
Jammer's Avatar
"Cometic does not list a ls1 head gasket with a 4.03 bore. Thanks for trying to **** me up."
he did you a favor and sent you to the BEST head gasket maker for LS1's... you rely on web info....gotta call them man....then see what happens. Fel-Pro makes a graphite one..
Old 03-20-2004, 12:30 PM
racer7088's Avatar
No one makes a 4.030 head gasket for anything unless it's custom because it would stick in the bore unless it was totally perfect at 4.030. It will usually be bigger like a 4.080-4.100 for a 4.030-4.060 engine.
Old 03-20-2004, 07:31 PM
hillis's Avatar
Lightbulb
Then it's decided. I will call cometic and felpro.
Old 03-21-2004, 08:29 PM
Jammer's Avatar
Fel-Pro graphite part # 9199pt
Old 03-22-2004, 08:51 AM
Super Moderator
Reckless's Avatar
There are plenty of folks using the 6.0L GM MLS gasket on 4.030 bore motors with no issues. Cometics and FelPros will also work.
Old 03-22-2004, 02:00 PM
DenzSS's Avatar
Yup. I'm using a Cometic 4.030 gasket on my 408 iron block. Even then, the gasket needs a little massaging. Just depends on how precise you want to be.
Old 03-22-2004, 05:03 PM
SStroked 410's Avatar
what would I need to do if I wanted a Graphite gasket but with a 4.040 bore? Felpro makes custom gaskets?
