is 10% leakdown acceptable?
Old 03-19-2004, 09:34 AM
v8maro's Avatar
Default is 10% leakdown acceptable?
like the topic says, let me know please.
Old 03-19-2004, 10:24 AM
Larry's Avatar
I had 4-5% leak down on mine. What size orifice are you using?
Old 03-19-2004, 10:27 AM
v8maro's Avatar
Stage 2 heads - forgot the sizes of the valves
Old 03-19-2004, 10:52 AM
Larry's Avatar
I meant the orifice in the leak down tester.
Old 03-19-2004, 10:53 AM
JS
JS's Avatar
IMO no dice...
5 to 6 % max....
Old 03-19-2004, 12:16 PM
Warbird's Avatar
What kind of mileage do you have on the bottom end?. 10% is pretty good for a well worn in motor
Old 03-19-2004, 12:39 PM
crainholio's Avatar
Generally speaking up to 20% on a cold engine is acceptable, and up to 10% on a running-temp engine is acceptable. Ring end gaps vary as a function of their temperature as well as the block's temp. Valves, however, shouldn't leak at any temp.
If you want to diagnose the source of your leakage, whip out a mechanics' stethoscope ($10 at Sears) and listen at the following locations, while the cyl is pressurized and the piston is at TDC:
1.) Throttle body or injector base: intake valve leaking (not good)
2.) Exhaust manifold: exhaust valve leaking (not good)
3.) Oil dipstick tube: rings leaking (OK)
Old 03-19-2004, 07:54 PM
v8maro's Avatar
just turned 37k miles
I will call him and ask him if the valves are leaking at all
-Steve
Old 03-19-2004, 10:40 PM
Mike K.'s Avatar
I thought 10 % is no good. I seem to remember 7-8 % being on the bad side of the max ok blowbuy.
Old 03-19-2004, 11:06 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
10% Is good imo i had a motor that leaked like a siv 80% in a couple cylinders. And when i went back to the track after it was right i didn't gain that much.
Old 03-19-2004, 11:33 PM
GueSS Who's Avatar
10% is fine IMO also. A brand new motor has 2-5%.
Old 03-20-2004, 12:08 AM
verbs's Avatar
I have 4-8% on all my cylinders......my motor loves revving to 7 grand
Old 03-20-2004, 12:28 AM
v8maro's Avatar
The reason why I ask is not a question of the rings really, I recently had a problem with a dealer breaking a valve spring, i was concerned about the valve being bent, now I am all paranoid that I have blowby UGH
lol
Old 03-20-2004, 12:35 AM
Mike K.'s Avatar
I wouldnt worry about it too much but you are towards the worse side of things. On the cylinder that had 10 percent where did you hear it coming out of? For a comparison I had 90% blowbuy and I was blowing my dipstick tube out due to crankcase pressurization,, you are nowhere near this and probably just have normal wear on the motor. Don't sweat it.
Old 03-20-2004, 02:20 AM
ls1jimmy's Avatar
I have got 25 % in one cylinder and the rest is at 2 and 3% i would like to know to because i had a cam installed and gained 25 hp from long tubs and cam ..
Old 03-20-2004, 08:20 AM
tuff's Avatar
Loosen the rockers up on that cyl and see if that helps maybe to much preload on the rockers.that will tell you were the air is going out if you have a problem.
Old 03-20-2004, 08:39 AM
crainholio's Avatar
And while you're loosening rockers, give each valve a tap with a soft-blow hammer to seat them. If the engine's been sitting a while, this helps get an accurate indication of valve sealing.
Old 03-20-2004, 10:43 AM
ls1jimmy's Avatar
I had a shop do it that what thay said thay did but i did a compression test and it had 180 in that cylinder
Old 03-20-2004, 09:00 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
Was the leak down check done with the motor hot or cold? This can have a big effect.
The LS1 (after re-ring) going into my RS had 42 & 35 percent leak down in cylinders 1, 3 cold. The another cylinder was a 25 percent and all the others were at 10 percent. I don't think 10 cold is too bad.
Old 03-21-2004, 01:35 AM
v8maro's Avatar
Cold for sure
Quick Reply: is 10% leakdown acceptable?
