Recommend Any Changes to my TSP 408ci Build?
I'm planning on ordering a TSP LQ9 408ci long block good for Nitrous that will be used for Street Driving, Road Racing, and Drag Racing. I want to maximize the power I can get out of the motor, so let me know if you would change any of the long block choices I made to make more power. I also have a few questions as well I hope someone can answer.
Wiseco -8cc Dish Pistons
Wiseco Steel Top/Napier Second Ring Set
Callies Compstar I-Beam Connecting Rods
Callies Compstar Crankshaft
PRC Stage 3.0 LS6 64cc Heads
Cometic Head Gaskets
Harland Sharp 1.71:1Non-Adjustable Rocker Arms
Texas Giant Camshaft
PRC EHT .675 Dual Valve Springs
ARP Bolts used Throughout
A few Questions I have:
Would you prefer K1 Technologies or Callies?
Are I-Beam Connecting Rods worth the extra money over H-Beam?
Are the PRC Stage 3 LS6 64cc Heads a good match for what I want, or should I go a different route? Such as PRC 215cc 62cc or PRC 227cc 60-62cc?
Did I choose good Rocker Arms for what I want to do with my motor?
Should I upgrade from GM LS7 Roller Lifters to Comp Cams "Comp R" lifter?
What Cometic Head Gasket Thickness should I use? .041, .045, or .051? Or would you recommend the GM MLS .058?
Thanks for your time guys! I plan to have this motor using a Fast 102/102 and TSP 1 7/8 Headers eventually. Immediately it would be using an LS6 Intake with Ported and Polished Throttle Body off my LS1, and my Pacesetter 1 3/4 Headers. Even with the LS6 and Pacesetters I'd still like to break the 500rwhp mark.
get the 237's and the pistons will probably be .008 to .010 out of the hole ( just guessing you will need to check ) so a .045 or .051 cometic will give you a good quench.
the harland sharps will be fine, that is what i have on my 237's. the ls6 intake will definitely be a restriction. later on the fast setup will really wake it up.you will need bigger injectors if not already upgraded. 42 lbers will work great.if you can run 93 octane i would get the scr atleast 11:7 or so. your dcr will still probably be mid 8 range which should be no problem.
it should break 500rw even with the ls6. with my cutout open on my 408 with ported 243's,fast 90/90 ported, 1 3/4 headers, 244/248 cam my rw is in the mid 53x range. m6, 9 inch,3;89 cogs.
yeah the extra cc's slows down your velocity some but with your cubes a 237 cc head will work great. especially with a properly built setup.have them to get you around 11:7 or alittle more scr / atleast 8:5 dcr and you will have a great running setup.
yeah i was looking more into that 6x cc and it sounds like i would want it lower than 68cc. Apparently the lower it is the more compression there is, so more horsepower and more torque. Hopefully I can get the 237 Heads in a 62-64cc, even though it wasn't an option. I'm pretty sure the Wiseco -8cc Dish would match that, I just need to figure out what gasket thickness would bring it all together. I'll give them a call tomorrow for sure
