LS3 heads on a 5.3 motor?
Is it possible to put the LS3 heads on a 5.3? Have heard it may have issues with valve to block clearance on the small bore 5.3 and want to see if anybody knows for fact. Is there anything like thick head gaskets that would help? I'm wanting to build a 600rwhp pump gas motor with a 76mm turbo. Thanks for any info.
correct me if I'm wrong but i believe the bore size is not sufficient to support to design of the heads. additionally you will end up having to go with a LS3 intake and bunch of other pains in the ***. There's no reason why you can't get your stock heads worked and make that kind of power... seems like people are doing it all the time now.
The Ls3/L92 heads require a min. of 4.00" bored (6.0 LS/LQ and up).
https://ls1tech.com/forums/generatio...-tfs-215s.html
