AI 241/PatG cam???
AI 241/PatG cam???
What do you think of this combo? Any guesses on power/suggestions?
AI 219cc 241s
222/228 .600 lift EPS cam
LS7 Lifters
LS2 Trays
LS2 HD timing set
Stock LS6 oil pump
Stock LS1 intake/ported throttle body
Stock 98 manifolds with magnaflow direct fit cats/catback
FTP lid/85mm MAF
stock rockers with trunnion upgrade
M6 with Texas Drivetrain stage 2 and diamond stage 2 clutch
10 bolt with 3.42 gears
42# SVO
Walbro 255
CA car so emissions equipment must stay...thanks!
AI 219cc 241s
LS7 Lifters
LS2 Trays
LS2 HD timing set
Stock LS6 oil pump
FTP lid/85mm MAF
42# SVO
Walbro 255
Looks like a pretty solid set up...I would guess around 430-440 to the wheels. Let us know how it performs once you get it on the road. I will be running the same heads by summer and really and hoping you have good results.
It should do nice for an emission compliant setup. The intake and manifolds are gonna hold you back on the top end. I think a nice rear end and gear should be your next mod.
Yeah I would like to do an ls6 intake I would just need to find an SLP intake or incorporate the EGR in the same fashion. Once the budget allows the rear end will get replaced but I need to get the car up and running first, it was purchased as a roller so there may be some unforeseen problems once everything is installed, you never know...
I'd add a Flowmaster Y-merge collector to the Y pipe to eek out alittle extra flow for not much dough. Like an X pipe, it'll also make the exhaust sound better with less rasp.
IMO, I'm surprised Pat didn't recommend more duration on the exhaust side with stock manifolds to help compensate for that restriction. I guess there's no point with the stock intake.
Jason
Jason
