L33 vs. 99 LS1 cam
L33 vs. 99 LS1 cam
Can anyone tell me if it's worth it to swap my L33 cam with an LS1? I will be using an LS1 intake manifold and throttle body.
I read in another thread that they wouldn't be very different. I can't seem to find much info on the L33 cam.
Just google "chevy L33 gen 3/4 camshaft" and read all about duration and lift for all the LS based gen 3/4 chevy engines ,,,,,,,,,,,,,Wikipedia is helpful for the whole GM engine lineup for all the basic stuff , but some of the other sites will be LS1 tech so clicking on an LS1 tech site will take You directly to a thread about what You typed in .
I can't find the exact specs on duration but the lift is .480 and duration is under 200 but higher than the regular 5.3 cam...I'm in the same boat as you with the l33...I'm going to swap mine for my stock 98 ls1 cam which is .500 lift and duration is 202/210...I don't have the cash for valvesprings and cam package
I guess in my opinion, swapping in an essentially free LS1 camshaft might be best for getting a truck engine swapped car project up and running and running with more "car-like" characteristics; the best part is with the L33 it works with the stock springs and pushrods.
Though I would agree that an LS6 cam would be a better choice, it actually costs money to do this one, so I would much rather skip this cam after a free LS1 cam setup and go straight for a big duration/lift setup with real hardened pushrods and springs.
Anyone else with me on this one? I'm working along with the OP on his project...
My brother builds his toys using a $400.00 computer program used to predict HP. The computed HP figures are not unreliable; but, the relative predicted behavior of different cam shafts is reliable.... or so he claims. His program predicts the earlier z06 cam is worth only 24hp over the stock LM7 and the 98 LS1 was 18 hp. But, and this was his point. The Ls1 out performed the z06 through 5500 rpm. Not too shabby for a completely free piece.
Bear in mind that any aftermarket ls1 cam will out perform the Z06.
The Ls1 and Ls6 manifolds look good, but the butt ugly truck manifolds have the reputation of running right with them until you hit 6K or so.
If you are paying labor to replace the cam, really consider spending a few dollars more for an aftermarket camshaft.
My six bits of opinion. Yeah, I went with the z06.... my closing argument to my self was I would bolt on a truck supercharger, radix or something.
G
Personally,
