LS1 rods in the LQ4? can i go from pressed to floating?
Old 02-10-2012, 03:36 PM
slammedlt1's Avatar
Default LS1 rods in the LQ4? can i go from pressed to floating?
I am lookin at a set of scat I beam that are being sold locally. They are for the LS1 and are "bushed" pin ends. Is there anyway I can use these with floating pins in the LQ4? I know theyre the correct length and theyre a wicked deal. any ideas?
Old 02-10-2012, 03:47 PM
93Z2871805's Avatar
Providing you have a floating pin/piston, yes you can use floating rods in a 6.0.
Old 02-10-2012, 05:03 PM
chrisfrost's Avatar
Just check the inner diameter of the rod small end bushing and make sure it matches You're piston pin as I've seen 2 different sizes of piston pins for the 4th gen engines .
Old 02-11-2012, 11:24 AM
slammedlt1's Avatar
thanks guys couldnt ask for better support from the forum.
Old 02-11-2012, 12:53 PM
bww3588's Avatar
most bushed pin rods are for a .927 SBC size wrist pin, LS1 pressed pins as well as floating pins are .944
get the P/N off the rods and check the small end diameter.
Quick Reply: LS1 rods in the LQ4? can i go from pressed to floating?
