stock oil pump questions
Im getting ready to do a cam swap on my car, since it only has 35,000mi on it I was wanting to keep my stock oil pump, but was wanting to port it and put a shim in the spring to get some more pressure. doe anyone have a thread or a write up on how to dissamble the pump to make those mods or have any suggestions.
Taking the pump apart is so easy, you don't need a tutorial. Remove the bolts holding the cover on, then pull out the gears. Just make sure you put the gears back with the same orientation as they come out... Don't flip them.
The allen bolt on the bottom comes out to remove the spring and plunger. Use blue loctite on that retainer when you reinstall. Do a search and you'll find plenty of info on porting, but once you open it you'll see exactly what to port anyway.
