Should I be upgrading my fuelpump on my 98 camaro for H/C/I?
So I was just wondering should I be uprgrading my fuelpump besides the injectors since I'm going from just being cammed to h/c/i, or will the stock fuelpump be sufficient?
It may not be needed but definitely an insurance piece. For a measly 200 bucks you can get a racetronix 255 with hotwire kit. I am making roughly 650 to the tire on spray with that setup and it is still going strong.
2001-2002 got the 28# injectors as well. It seems to be about 50/50 with people swapping out the pump with H/C. I'd say injectors for sure, I'm going to see how it does on the dyno with fuel pressure before I make my decision to change it. I have the kit but really don't want to change it if I don't have to.
Captain Double Post
Don't skimp and get a raxetronix kit for the car. You need to upgrade the old fuel pump
Leave your pump alone and replace it when it dies. You can actually spend a Ton of money on your car if you want to but is it really necessary.......only you can make that decision. I had my engine top end rebuilt and replaced my pump with a stock GM pump and I am doing fine, it is my DD.
Recently did some research on this myself. From what I read, stock pump is good to 450-ish rwhp. I just installed a racetronix kit for my upcoming AFR/fast 102 build as i'd rather drop the 225 on the kit than go lean.
cool, thanks fellas I think I will go with the racetronix fuelpump assembly in the red anodized thingy, since I do plan on spraying in the future after I get a rear first.
