Torquing head bolts and coolant
Old 02-12-2012, 12:39 PM
Ronny_02_WS6's Avatar
Default Torquing head bolts and coolant
I had my heads off for cleaning and valve springs replacement cause I' going with a cam and I blew block holes/threats with air but it seems that there is still a Little coolant on the last hole in the bottom of each side would a little bit of coolant hurt the engine or do I have to make sure that there's no coolant in the holes period???
The following users liked this post:
tonyreyes (11-20-2021)
Old 02-12-2012, 12:49 PM
Grimes's Avatar
no coolant in the holes. PERIOD.
Really, don't even try leaving any in them. Duct tape a straw to a shop vac hose and get in there. Also you can try rolling up some paper towels thin, and shoving them down.
Old 02-12-2012, 01:07 PM
wildcamaro's Avatar
Yea paper towels are it...
Old 02-12-2012, 01:56 PM
Thanks guys, I rather be safe than sorry!
Old 02-12-2012, 02:12 PM
baxsom's Avatar
just one drop can cause the holes to hydro lock when you are torquing down the new head bolts and crack your block
SAPPER (11-21-2021)
Old 02-12-2012, 02:39 PM
Dang, Even if you don't screw it all the way down???, just to have the heads sitting with the bolts half way???
Old 02-12-2012, 02:47 PM
baxsom's Avatar
check these forums, there are numerous posts about people that have cracked their blocks because of tiny amounts of coolant in the bolt holes. there is a reason why all of the how to's stress so much the importance of cleaning the holes out and making sure they are perfectly dry, as soon as you start torquing the bolt, pop. it is because the water doesnt compress and builds up pressure from the bolt pushing in on it. the pressure has no where to go so it cracks the block.
Old 02-12-2012, 03:08 PM
hardcore4sure's Avatar
Yea I was probably one of the first people this happened to. Luckily it was a GM tech who did it and after a small fight they replaced it with and LS6 block. X2 on noooooo coolant at all in the holes.
Old 02-12-2012, 10:30 PM
yaknow's Avatar
good advise, thanks
Old 11-20-2021, 01:14 PM
tonyreyes's Avatar
Default I mest up?
I had colant in my block and screws in the bolt and heard pop and a little bit of coopant seaped out what does that mean
Old 11-20-2021, 01:41 PM
01CamaroSSTx's Avatar
Received 1,785 Likes on 1,293 Posts
Age old thread but basically what that means is that your block is toast and you should give it to me...
On a serious note though it is really important to clear the holes of any coolant so used compressed air and chase the threads until they're clean otherwise you risk cracking the block once you run it.
Old 11-20-2021, 01:52 PM
pdxmotorhead's Avatar
I use brake cleaner to flush the holes then compressed air will dry the hole out and evap the brake cleaner. Wear your PPE...
99 Black Bird T/A (11-23-2021)
Old 11-20-2021, 02:39 PM
QwkTrip's Avatar
I drop Q-tips in the holes and let sit for a few hours. Repeat as necessary.
You'll be surprised how much extra soaks up when you just let it set for a while.
The following 2 users liked this post by QwkTrip:
G Atsma (11-20-2021), ls1leadfoot (11-29-2021)
Old 11-20-2021, 04:43 PM
dixiebandit69's Avatar
I made an attachment to my air-blow gun that is an 18" long piece of 1/4" copper tubing (long and reasonably flexible, to get into tight spots if necessary), and I stick that down the holes to blow out any contaminants.
Been working good for years.
Old 11-20-2021, 10:02 PM
bbond105's Avatar
It means that there is a good chance you cracked your block.
Old 11-21-2021, 12:43 AM
QwkTrip's Avatar
That's a neat idea. I need me one of those!
Old 11-21-2021, 01:59 PM
SAPPER's Avatar
OK, I used to do this almost every day at work (GM Tech) The best thing to use is a Harbor Freight Brake bleeder. Hook it up to air and cleans out the cylinder, bolt holes, whatever. Tip: Cut the hose inside the canister halfway off.
I use this to suck out coolant out of bolt holes, off the pistons, etc.
Then take an old head bolt, cut 2 lines up the threads with a cutoff wheel and you have a cheap thread chaser. Blow it out and your set.
https://www.harborfreight.com/brake-...der-92924.html
And BTW, if you heard a POP. you cracked the block.
G Atsma (11-21-2021)
Old 11-22-2021, 10:15 AM
gagliano7's Avatar
I taped a straw inside my shop vac hose. Sucked all the coolant out easily and quick.
Old 11-22-2021, 01:48 PM
02EBC5Z06's Avatar
I quarter up a paper towel sheet, roll them up with a tapered twist. Stick them in the holes for an hour each. This wicks up the oil and coolant. I do that twice, then use a blow gun to blow the crap out. Then I chase the threads with the arp tool.. Followed by a little acetone in each hole for a minute or so, then blow out again with the gun. That should get them as good as new.
Quick Reply: Torquing head bolts and coolant
