best timing chain
Old 02-13-2012, 08:04 AM
aAZz's Avatar
Default best timing chain
Doing a cam swap on my 6 liter so decided I would switch out my stock timing chain. I don't want to do a double so wondering what's the most inexpensive timing chain set I can go wit on a big cam set up?
Old 02-13-2012, 08:27 AM
payanhilario's Avatar
i think ls2 chain is good and cheap
Old 02-13-2012, 08:39 AM
njmaster's Avatar
I second the LS2 timing chain. I got mine with everything for $65
Old 02-13-2012, 08:44 AM
MJs1FastSS's Avatar
hit up yank he has everything you need
Old 02-13-2012, 11:08 AM
wildcamaro's Avatar
Ls2 which you can get from gmpartsdirect.com for less than 40 bucks...unless your cam/crank gear have wear then replace them as well
