A couple questions for the experts.
I installed a set of PRC dual valve springs and i used Precision Engine Products retainers and locks. After bolting down a rocker arm i noticed that it was damn near touching the locks but appears to be pushing on the valve still. Is this ok to run this way? The last time i did this i used a different set of springs/locks/retainers and the end of the valve was sticking out more. To me this didn't look right.
Also, i was checking pushrod length since i installed a new set of PRC 2.5 5.3 heads with 62cc chambers and GM Performance MLS gaskets. The pushrods i have been running are 7.400". I tightened down the rocker (in the picture) there is no slack between the rocker and the pushrod and the rocker is firm on the valve without compressing it. Does that mean the 7.400" rods will work?
