Need Timing chain, oil pump, and ring info PLEASE..
Ok, everyone. It's almost that time. Ordering the cam that Pat G spec'd for me today. I need a timing set. What do you guys recommend? Also need a recommendation on a ring package. My build is as follows.
Carb'd LQ9 (stock pistons) with LS3 heads. It's mostly gonna be a bracket car, but will get the occasional 150 shot for the hell of it. Don't know if I should go with a stock ring or a set of Hellfire's or what. I can't find any part #'s for the Hellfire's. It will be standard bore.
Also, what Oil pump? I'm using a F body pan. Should I go Texas Speed ported, high volume, etc?
TIA
TIA
