Removing Bottom / Lower Timing Gear, What Tool to Use???
Old 02-15-2012, 07:35 PM
Evans752's Avatar
Default Removing Bottom / Lower Timing Gear, What Tool to Use???
Hello there, I am in the process and haven't been in these engines in 7 or 8 years do to physical ability, anyway what type of tool are you all using to pull it? I have a 2 prown puller and 3 prown puller and they won't fit as they are behind the lower pulley to block. Is there a specific way you all are pulling them or a tool that I can rent from places like Autozone, Advanced Auto Parts by chance? If so and if you know what one and/or the part number for it I would GREATLY APPRICIATE IT. THANKS SO MUCH IN ADVANCE FOR LOOKING AND / OR REPLYING!
Old 02-15-2012, 07:44 PM
David Q's Avatar
Don't go crazy prying on it, but wedge a flathead screwdriver in behind it and apply a little pressure. Move around on the sprocket, and it should pop right off.
Old 02-15-2012, 08:43 PM
3rdCoastPowerSports's Avatar
3 jaw puller works every time
Old 02-16-2012, 12:08 AM
bww3588's Avatar
I got a small 3 jaw puller from autozone. It had thiner jaws that fit perfectly behind the gear. Just take care and make sure you protect the end of The crank from damage.
Old 02-16-2012, 09:13 AM
bczee's Avatar
This is the correct type of tool to use.. and what I used.
I think it was a Kent Moore J-41558 costing about $10-$15 or so... you can find them on ebay or searching oline on your local parts store (not autozone or etc.. maybe Napa ?.)
Old 02-16-2012, 01:32 PM
01ssreda4's Avatar
A smaller 2 jaw works very well for this and they are cheap/easy to come by. Prying behind it with a screwdriver??? No
Old 10-09-2012, 03:09 PM
Shockwave179's Avatar
Alright I'm rather annoyed and looking for help on this one.
Ordered the J-41558 and had a feeling it wasn't going to be the complete tool pictured here. Well it arrived yesterday and I was right. The plate that sits behind the gear, the 2 bolts and 2 washers are what came in the 41558 package but the other pieces in this picture are not included. Does anyone have a Kent Moore part number or numbers?
Old 10-09-2012, 03:39 PM
The Scammer Hammer
dr_whigham's Avatar
I rented the autozone tool twice, in both sizes, and 2 or 3 arm configuration wouldn't work. I even made a drunk rant thread about it
The one from Advance Auto worked like a CHARM though. Took more time to set up the arms than it did to pull the gear off.
Best of luck with the Kent tool. It's nice, that's for sure.
Old 10-09-2012, 03:43 PM
NVR_SPDS's Avatar
If im not mistaken, thats just a balancer puller. You can find them just about any where.
Old 10-09-2012, 03:44 PM
midevil1's Avatar
The rest of that tool is just a standard Harmonic balancer puller. You can get it at any parts house. Lisle is a good brand.
Old 10-09-2012, 03:52 PM
Thanks guys, appreciate it. I guess I have to make a trip to the store tonight.
Old 10-09-2012, 11:23 PM
01ssreda4's Avatar
Yep, standard balancer puller in that pic.
Old 10-10-2012, 09:01 AM
RonSSNova's Avatar
Even though you bought the tool, and a balancer puller by now.....
For the rest of the guys reading with the same dillema.
You can make the plate from 1/8" steel. A hole saw cut's the relief, die grinder to shape, and drill and tap for the holes. Then 2 long bolts and the balancer puller.
Ron
Old 10-10-2012, 11:11 AM
ace32x's Avatar
great info! need to pop mine off tonight myself XD
Old 10-11-2012, 06:46 AM
RezinTexas's Avatar
it seems to be just luck of the draw with the gear pullers on this one. I got a generic 3-jaw from Autozone and it worked perfect, others have reported some that don't work or just slip off...
Old 10-11-2012, 08:51 AM
badazz81z28's Avatar
WELL WORTH THE $$$$!!!!!
I spent hours and knicking my block trying to get it off with a three jaw. Used the correct tool, it was off in 5 minutes and slid off easily. Many Kent Moore tools are expensive, but they sure do make the job a hellava lot easier.
Old 04-28-2022, 12:37 PM
Headflyboy's Avatar
Default Autozone Tool
All you need in addition to the J-41558 is the harmonic balancer puller from Autozone and that part number is 29017. Those two tools combined took me less than 2 minutes to have it off
Old 05-02-2022, 11:03 AM
Old Buzzard's Avatar
^^^ Only 10 yrs late. He's probably already done with the job.
Old 05-02-2022, 11:44 AM
grinder11's Avatar
Hope he's still above ground!!!
The following users liked this post:
Old Buzzard (05-02-2022)
Old 05-02-2022, 08:47 PM
CattleAc's Avatar
What? G Atsma has the day off...???
Quick Reply: Removing Bottom / Lower Timing Gear, What Tool to Use???
