spinning motor over 8K rpm?
Old 02-18-2012, 04:37 PM
3rdCoastPowerSports's Avatar
Default spinning motor over 8K rpm?
can you build an LS to spin 8,000 9,000 or even 10,000 RPM? my gsxr spins 14,000 rpm, why cant my LS?
Old 02-18-2012, 05:48 PM
sepsis's Avatar
Reciprocating mass.
Your bikes internals weigh much less allowing it to spins higher, like F1 cars.
I'm sure you could get a LS to spin that high, but it would not be cheap. Valve train would have to be the best of the best along with the bottom end.
Old 02-18-2012, 05:56 PM
JWStevens's Avatar
Spend a ton of money and you can. The 69 in my profile pic shifted at 8k all last year and our pro mod is a 540 and it shifts a 9800. RPM's will kill anything though!
Old 02-18-2012, 06:31 PM
mpatton's Avatar
Lol....
Old 02-18-2012, 07:05 PM
Originally Posted by sepsis
Reciprocating mass.
reciprocating mass. i understand the theory but with larger pistons and crank shouldn't strength increase with the size. therefore allowing you to spin the larger motor at the same rpm as the smaller motor?
Old 02-18-2012, 07:07 PM
what would this ton of money i would be spending buy me? billet rods? what would be the goal, to lighten the internals as much as possible?
Old 02-18-2012, 07:24 PM
sepsis's Avatar
Yes, strength increases with size, but so does weight. Now I'm no mathematician or physicist , but I know there are certain physics involved when dealing with weight and speed and such that make it hard to whip those pistons and rods around.
Hopefully someone smarter than me can come in here and give you more info, I just know a little about a little.
Old 02-18-2012, 07:41 PM
JWStevens's Avatar
The weight of everything makes a big difference. Its easier for a motor to yurn up higher if its got aluminum rods, light pistons, and then when you balance it the crank will be lighter too. On our pro mod we run titanium valves so the valve train can recover fast enough. You also have to be able to get enough air in the motor to let it pull that high too. The head and cam has got to be made to work that high. If you shorten up the stroke its easier also.
Old 02-19-2012, 12:24 AM
bartmanC5's Avatar
There's a guy over on CorvetteForum that took this route. His name is RobZ, and I remember seeing a couple Youtube videos. If I remember correctly, he had a 427 block that was destroked to 388 with a $$ valvetrain, but redlined at 9000 rpm. Sounds pretty sweet.
http://www.youtube.com/watch?v=PaxE6dsfb_o
Old 02-19-2012, 12:28 AM
sepsis's Avatar
That sounds awesome.
Old 02-19-2012, 12:48 AM
JWStevens's Avatar
I can't see that video because of my gay *** goverenment issue Blackberry! I don't know a lot but I do know that when we shifted the blower motor at 8,800 we never had any trouble. When we went to 9,800 we started having more issues. Some of the hemi guys turn theirs 10,200 but I think they only run a 4" stroke.
Old 02-19-2012, 12:53 AM
Blk98Vert's Avatar
Head choice and cam profile determine rpm too. A stock LS7 can rev to 8000 but GM set the limiter at 7 because there was nothing to.be had over that rpm
Old 02-19-2012, 01:10 AM
JWStevens's Avatar
Yeah, the 421 in my partner's 69 camaro was shifted at 8k and it has oliver rods and they're heavy. It has a 330 canted valve head and the cam is 292 @50 so you had to turn it pretty hard.
Old 02-19-2012, 09:21 AM
garygnu's Avatar
talk to any stocker or super stocker running a ls engine.watch some nelson racing engine vids with a ls motor.
Old 09-10-2013, 10:11 AM
MDMitch87's Avatar
your bike runs H beam rods and a flat plane crankshaft ...
It has Ti retainers and stuff like that.
Less mass = more RPM
Bore - stroke ratio is something you want to take a look at too.
Old 09-10-2013, 02:38 PM
baronsmith98's Avatar
Just think about an F1 engine. They currently run 2.4l n/a V8. But their stroke is only 1.56 in. And they use pneumatic valve springs allowing them to turn 18,000 rpm. Traditional metal valve springs become obsolite at a certain rpm depending on camshaft design. Having a shorter stroke will lessen the inertia the crank, rods, wrist pins, and other bottom end components are subjected to.
Old 09-10-2013, 03:10 PM
badazz81z28's Avatar
I would think you would only want to spin an engine as high as you needed to make the power.
Old 09-10-2013, 05:15 PM
miami993c297's Avatar
In the video below is my LS3 418 CID/ 664hp pump gas NA...my DD and high speed fast straight lanes...only revving 7500 rpm!
The valve-train only is expensive and high maintenance:
Christian
Old 09-10-2013, 05:34 PM
TurbopigB4C's Avatar
Why the ancient thread revival?
Old 09-10-2013, 05:53 PM
Ferocity02's Avatar
The stroke of a GSXR 600 is only around 1.7" which mean a much slower linear speed of the pistons/rods. The LS engine stroke is around 3.6", which is more than double the GSXR, which means more than double the linear speed for the same RPM. Keep in mind each piston and rod must accelerate to full speed and then stop TWICE on every rotation of the engine. That's a lot of stress!
Quick Reply: spinning motor over 8K rpm?
