Draining coolant from block
Old 02-21-2012, 12:56 AM
hcb1700's Avatar
Default Draining coolant from block
Hi guys, I'm replacing the head gaskets after finding oil in the coolant/radiator. I also found what appears to be coolant in the power steering resovior. I want to drain all of the coolant from the block and would like to know if there is a way to do so now that I have the heads of? Is there a plug that can be removed, or should I do the process described in some threads that involve removing thermostat and opening the drain ****, etc... Once I put the engine back together?
Old 02-21-2012, 12:58 AM
Bobby vanmeter's Avatar
I'm new on here and am not sure how to ask questions, can you help me out?
Old 02-21-2012, 01:01 AM
hcb1700's Avatar
Just click on the desired section(I.e. gen. 3 internal engine, etc...) and click new post to start a new thread. Welcome to the forum by the way.
Old 02-21-2012, 01:09 AM
Thanks
Old 02-21-2012, 05:28 AM
RezinTexas's Avatar
My '04 5.3 iron block has a coolant jacket drain on each side:
8mm allen plug under cylinder #8
17mm allen plug under cylinder #7
Old 02-21-2012, 05:43 AM
Spartan7's Avatar
Same on my 01 LQ4. I found a 17mm hex at Autozone.
Old 02-21-2012, 09:44 AM
hcb1700's Avatar
I'm going to check those areas. I want to get all of that oil out of he water jackets and radiator. I hope I can get to them though since its tight space in these f-bodies.
Old 02-21-2012, 10:11 AM
joecar's Avatar
Make sure you either remove or otherwise protect the starter and alternator (F-car) from the coolant that drains out.
Old 02-21-2012, 11:34 AM
hcb1700's Avatar
Originally Posted by joecar
Make you your either remove or otherwise protect the starter and alternator (F-car) from the coolant that drains out.
Will do. Thank you guys.
Old 02-21-2012, 06:13 PM
RezinTexas's Avatar
also, keep in mind there are 2 oil passage plugs next to the cooling jacket (under cylinders #1 and #7). These are also 8mm allen plugs and look the same as the coolant plug under #8. Don't confuse them!
Old 10-18-2012, 11:25 PM
SS125's Avatar
Unless something is seriously wrong with my LS1 block, there was a drain plug for the coolant under #8, had to remove the starter to get to it. However, the 17mm plug on the drivers side of the block was under #1 on my block. I just undid everything tonight to drain the entire cooling system. I'm pulling the heads off to check for a crack or head gasket on the even bank so I wanted all the water or coolant out. I didn't see any other drain plugs on either side for oil. I wish there was.
Quick Reply: Draining coolant from block
