You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
I am aware that the dyno chart in the link has more power but there are a lot of other things different as well, so the other link where only the heads were changed is still an interesting comparison.
5.3 heads are damn near given away. Quoting new price is silly, takes away the whole advantage of using a stock head.
Also, TFS and other aftermarket heads require roller rockers for about $400 whereas stock heads do not. Hidden cost of some aftermarket castings.
My understanding is that you can run stock rockers with a shim kit on TFS 215'S. Also, I imagine new prices are inflated, but it's a worst case scenario.
__________________
1998 Camaro Z28 - Six Speed - H/C/I
2008 Cobalt LS - DD
2005 CBR 600RR
Excellent points. But you gain some weight with most aftermarket heads,most need or should use aftermarket rockers/guides. Its really a good argument for both sides.
Thanks. I'm debating with myself on which route to go. If I do ported 243/799 heads, I'm going to go with Ed Curtis at Flowtech Inductions. I saw on one of the LS1GTO forums a guy with Ed's CNC'd 243's and one of Ed's custom cams make 463/418 to the tires. I believe that was also with an LS6 intake. I like your point about aftermarket rockers/guides when going with aftermarket castings. Would these be required if you went with AFR heads?
__________________
"The Mongoose"
2002 Pewter Trans Am WS6, M6 w/ LS6 Block
ASC# 1489
MODS: Advanced Induction CNC'd Dart/RHS 223cc Heads, Tick Performance SNS Torque Max Stage 2 Cam, Brian Tooley Racing .660 Spring Kit, ARP Rod Bolts, Accell 44lb/hr Injectors, Stainless Works Long Tube Headers, Texas Speed 3" True Duals w/ Bullets, SLP Lid, NGK TR5 Plugs, MSD 8.5mm Wires (Red), Monster Stage 3 Clutch Kit w/ Tick Master Cylinder and CCW 505a's (19/20)
Whenever they use bronze guides, after-market rockers are preferable. Otherwise guides will wear out prematurely. Another option is to use stock guide materials.
well we ended up going with the prc 215's.We did this for a number of reasons,but the biggest reason is we can order them with 62cc chambers and keep lots of ptv clearance at the same time.I plan on setting him up with some .040 or .045 cometics with this setup.This will allow us to keep his compression high,good quench and much better efficiency. We didnt want to flycut or mill the heads,and wanted to be able to slide in a larger cam in the future if he does gears or wants to change his setup.We got the heads with the powdered metal guides for greater durability with the factory rockers.Overall he is going to have a nice setup with great average torque and great power up top.I am hoping to get him to 440 with his ls6 intake.
__________________ 2000 Black on Black WS6, m6.
Stock catback,DMH cutout,Monster stage 3 clutch, katech rod bolts, comp 228/230 112 cam,Bo white ls6 heads(300cfm -stock valves)dynatech supermaxx header system,42lb injectors,BG ram air,slp pulley,lc-1,hp tuners. Ported Fast 90/90 .speed density tune.MWC 9 " 4.11 gears
441 rwhp 402 rwtq
11.9 at 119 ( Traction?)
Link please.
__________________ 2001 NBM TA WS6 # 1,195. WS6 Store Short Stick, SLP Lid, Kooks LT's/Catted Y, Borla catback, BLS 6000k Low Beams, Tuned by Frost, Fikse FM10, Koni 4/3, BMR Springs, Founders PHB.
dam this was a good *** thread! I picked up some PRC 215s used on here about 2 months ago for 1525. I still haven't put em on but when i do im hoping to gain at least 40whp through my auto and 12 bolt.
I think the ported ls6/ls2 heads are a great head and flow good numbers. but for a few extra dollars why not get the prc 215s? you can still run the stock rockers. either way you go im sure your gonna be satisfied with the gains and performance. your debating over 2 great heads so you cant go wrong here.
TSP have Aaron send me some PRC227s at 57cc and i will back to back test them vs my TFS215s...Just need you guys to turn down some ls3 valves and it will be an A-B comparision with a car that puts down 525rwhp now and runs 9.8s...If they make more power i will gladly purchase them and I am sure you will sell a ton following the results...
I can document the whole process too, with a bunch of pics and videos
If you already have the 243/799 heads, sending them to AI, getting them fully ported for $995, I would say that is the most budget friendly head out there. And with the right cam can net some really good numbers.
2) Better chamber design. The stock chamber isn't always ideal. When you cnc the stock head it opens up the chamber. So you have to mill them to raise the compression back up.
Unless you can TIG weld some material in there and then re-shape. (799's with full valvetrain) 51cc chambers that still flow well. Around 13:1 compression. Someday I'll have some dyno numbers for this thread. A good 3-6 months away.
__________________ L33 5.3 punched out to 5.7 liters. Aluminum block. LS6 pistons and heads. Welded in chambers, Ferrea hollow stems, and .650 lift PRC springs. Max effort Port and Polish from GTP Houston. Magic Stick 4 Cam. Stock rockers with Comp Cams trunion upgrade. (for now) Double roller adjustable with chain gaurd. ARP rod bolts. 5 gallon 4 stage ARE dry sump with a 5.5" Tilton 4 disc clutch. Have yet to build headers. Dropping it all in a caged 944 turbo Wide body. Stock 5spd.
^^very nice...why not just get some custom pistons though to bump the compression?
__________________ Stock Internal with SS3600 rw 3365lbs 11.558 at 116.24 MPH 1.546 60ft DA -832 11/25/07 Cam Only and SS4000 10.617 at 124.66MPH 1.356 DA -870ft Race weight 3250lbs H/C/I 9.82 at 134.8MPH 1.281 60ft DA -500ft Race weight 2950lbs on slicks
Link to get Non A/C ram air http://www.speedinc.com/cont.cfm?cid=C0000984
I try to inch out every bit where I can. Custom domed pistons are not the most efficient way to go. A flat top piston promotes the best burn from everything I have read. The dome top can offer too many inconsistencies with burn performance. It can be done, but the flat top keeps it elegant and simple. Although domes would be cheaper. Custom chamber work like this gets a bit pricey. Well beyond that of a dedicated casting if you get crazy like I did. This head is a pure gamble and might just be an extremely expensive moderate performer. I am dying to find out, but its going to be many months.
One would think, being more consistent with compression volume across all 8 cylinders via changing out the piston is better than than the human variance of adding material to each chamber and then grinding/polishing in both pairs of heads. Dont get me wrong, its fantastic work...
I have heard of A.I. heads outflowing trickflows on the same machine on the same day. I wasn't there so I can't validate the statement. What I do know, is that there are some nasty fast cars out there running factory castings.
I've never seen or heard of a set of AI's outflowing TFS215s. I've seen where AI 243 heads were flowing 299-302 cfm @ .600 lift, however, eventhough they flow less than other heads, they produce some of the best dyno numbers. TEA 243s flow in line with Trickflow 215s, I believe somewhere around 322cfm @ .600. These are just peak numbers, TFS 215s flowed much better between .200-.500.
Both AI 243/799s and TSP 243/799 heads lay down some good dyno numbers.
